Question about HP Office Equipment & Supplies
My new fax hp lp7590 has on screen alignment failed tried everything to fix
Why dell? It is an HP printer.
Posted on Oct 03, 2008
  • 162 Answers
Hp has been sending stuff from the factory bad lately, take it back or call dell to replace item.
Posted on Aug 12, 2008
Go to control Panel and Open Printer and Faxes
Open Printers Toolbax and Click Utility and RE ALLIGN CARTRIDGES
Feb 17, 2011 | HP Office Equipment & Supplies
Fax will not work at all. I have reloaded the software, unplugged and replugged everything, talked with HP(they want a fee to talk) When you turn it on, it is a "fax failure" message. Will not send or...
Try to Run Fax Test
Press the Setup button on front panel
Scroll to Tools - Press OK
Choose Run Fax Test - Press OK
It should print the Fax Test Report.. it will list you the possible cause why you are getting Fax Failure..
If it says Hardware Test a Reset on the Printer ( Hard Reset )
this will printer reset the settings to Factory default like your rings to answer will change to default, Speed Dial list will be wiped off
Steps to do :
Disconnect the Phone cord from EXT 1 of printer
while the printer is on, Disconnect the power cord from back of printer. While holding the # and 6 Buttons, connect the cord back and release the buttons after 5-6 seconds..
go thru the alignment process and re-align the printer
Connect the Phone cord back and try to Run the Fax Test and check if everything passes in the list.
Jun 25, 2010 | HP OfficeJet 6310 All-in-One Printer...
The fax machine requires the alignment function but the alignment fails.
Replace all ink carts with new GENUINE HP carts for a sucessful alignment.
Jan 14, 2010 | HP 1220xi Plain Paper Inkjet Fax
I have the hp d1400 wont print and its telling me i have an alignment all stemed from me changing my printer cardridge
Align the new print cartridge
  1. On the Windows taskbar, click Start .
  2. Click Programs or All Programs , click HP , and then click HP Solution Center .
  3. In HP Solution Center , click Settings , click Print Settings , and then click Printer Toolbox . The Printer Toolbox opens.
  4. Click Align the Print Cartridges .
  5. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and calibrates the printer.
  6. Recycle or discard the test page.
Mar 11, 2009 | Lexmark Office Equipment & Supplies
Printer Alignment Failed in HP C5280
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Jan 18, 2009 | HP Photosmart C5280 Printer
Cartridge alignment failed on a C5280 HP printer
I had the same problem after changing the black cartridge. After trying everything i found online to fix this fault and replacing the new black cartridge again, i replaced the tricolour cartridge even that it had a quarter ink left! This solved the problem, I think the colour was abit weak for the printer to check alignment.
Try it, it worked for me and good luck
Dec 07, 2008 | HP Office Equipment & Supplies
My HP DeskJet g85 says "cartridge alignment has failed"
Here is the weblink which helps you in resolving cartridge alignment failure issue:
Click on the link above and follow all the steps give in web document.
Thank you.
Dec 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Alignment failed notice
Could be one of two things....
1 - you may have bad cartridges...when the machine does an alignment it looks for specific marks on the check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Change cartridge (color first) before doing anything.
Oct 24, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
108 people viewed this question
Ben Johnson
