Question about GN Netcom GN 9120-28 Wireless Headset
Not ringing in the headset
GN Netcom 9120 wireless and it won't ring in my ear so I can't hear if the phone is ringing if I'm away from my desk
  • kkeyzers Jan 28, 2009
    i have the gn 9120 headset and i am not able to figure out how to se it to make it ring in the headset itself instead of on the external phone, the problem is when im away from my sedk i am not able to here my phone ring.
  • it91 Feb 02, 2009
    I'm having the same issue.
5 Suggested Answers
SOURCE: GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Posted on May 19, 2008
SOURCE: GN 9350 Wireless Headset doesn't ring on the headset when phone rings
It only picks up certain digital rings. I changed the ringer on my phone and had the same problem. To fix it, I had to plug in the little microphone that plugs into the handset lifter and place the mic over the ringer speaker. Now it works fine.
Posted on Mar 18, 2009
  • 4 Answers
SOURCE: No sink?
Yap i did solve the issue, thanks
Posted on May 28, 2009
  • 94 Answers
SOURCE: I just got the Jabra
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Posted on Jun 15, 2011
GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
Feb 19, 2009 | GN Netcom GN 9120 Professional Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
Jul 11, 2008 | GN Netcom GN 9350 Wireless Headset
Jan 30, 2008 | GN Netcom GN 9120 Professional Headset
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
Incoming alert
Generally you will get a ring in the headset when a call is detected by the lifter that you use or if you don't have a lifter then you would have to use the little microphone that comes with the unit and affix that to the speaker on your phone so that your GN 9120 knows when to alert you of a call.
Aug 31, 2007 | GN Netcom GN 9120 Professional Headset
GN Netcom GN 9120-28 Wireless Headset Logo
103 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
techmncpa
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
