Question about JVC AM FM CD DET FACE CAR STEREO
JVC detachable face with auxillary input
System works great except for one thing... the fm radio reception. Some parts of town is barely ok and in others no signal. Installed on a 1998 Honda Accord. All other features work just fine. What's the deal?
  • 113 Answers
How is the reception on AM ?- if the antenna is the problem you won't get any reception on AM !!!! If you can get AM on two or more stations the antenna is not your problem- if you get AM reception and don't get FM the problem is the fm tuner in your Honda radio( usually it would need several solder joints redressed)- we repair these factory radios -Merle840@aol.com. (908)-756-3544
Posted on Sep 05, 2008
  • JVC Master
  • 5,568 Answers
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Posted on Aug 25, 2008
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
I can't get the AM radio to find a signal. All other components work fine.
Hello
If you get FM radio stations, and only AM reception is immpossible, check whether AM loop antenna has connected to the respective poles at the back side. If it is connected, and still you do not get the Amplitude Modulation [AM] signals, check the input settings of the device is correct to recive AM. There will be a slelection option, for AM & FM. OK.
Jan 22, 2012 | Audio Players & Recorders
I have a jc penney car stereo, am/fm cassette (service # 682-0392-00) that has very poor reception at its best. It is not a problem with the antenna, that has been changed and substituted with one from my...
You can purchase a in-line amplifier to boost radio signal, or just buy a new deck for less than $100 and get it installed. Great deals out there for decks below $100 installed. Try Best Buy or Fry's electronics.
Mar 15, 2010 | Car Audio & Video
Bad reception fm radio signal
usually batteries...am takes less juice.....battery strength will affect fm signal strength
Nov 08, 2009 | GPX RDT4004SP AM/FM Radio
No AM reception for car radio...do get FM reception.
I was having the same problem with a jvc kd hdr 30. I Installed it myself over a year ago and never wanted to deal with the issue. Finally, I decided to take a look at it today.
On my head unit, all wires were connected except one blue one with a tag that says "do not connect to power, for remote device or power antenna only." This unit is in a '97' MBZ E320 with no visible antenna; I think it is part of the windshield. In any case, between the wiring diagram in the manual and the harness that is part of my car, I was left with 2 blue wires to choose from, one with a white stripe and one with a gray stripe. After testing both for power or ground, I determined neither had power with key on or off. Both had high resistance ground when compared to the chassis ground. In other words, I measured between chassis and these wires. First, I took a wire and connected it to the chassis ground and connected the other end to the blue wire coming from the unit while tuned to a local am station. This simply killed all reception am or fm but did not harm the unit. Next, I connected the blue wire with gray stripe of the car harness to the blue wire of the unit and again this killed all reception. Then I connected the blue wire with white stripe of car harness to the blue wire of unit and presto magic I had great am reception.
I am guessing that this blue wire with white stripe must be part of the antenna itself or perhaps is a connection that increases antenna power. Maybe 'power antenna' on tag refers to an actual powered antenna (like as in amplified?) and not as in an antenna that rises up out of fender, as I believed.
This may not help the first person with the question, but maybe it will help someone out there who searches for these kinds of answers like I do from time to time.
May 31, 2009 | JVC KD-PDR30 Car CD/ MP3 Player
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
AM radio reception
You are correct William, reception is not what it used to be for many reasons. Some corporate owners and local owners have spent much more maintaining FM facilities, and many have neglected the AM's. A good part of the AM signal is via the ground radials beneath each AM tower. In time these radials deteriorate, and with it the signal. Years ago stations licensed as daytime only shut down at night. Quite a few are now allowed to stay on with greatly reduced power, adding to the noise floor at night. You also have more AM licensees now than in the 60's. Unfortunately many of the really knowledgeable AM RF engineers have retired, or are close to doing so. AM directionals require a very experienced engineer. In addition we have many Part 15 radiators, that are devices that radiate a low level RF signal. Every home is full of them, thus more interference. We have power distribution systems that generate huge amounts of noise across the band too. Then there is the issue of manufacturers who have spent more on the FM receiver side of a radio as more migrated to FM. In the 60's, very few were FM listeners. Gone is sensitivity, selectivity and frequency response in the newer AM radios. There are a few exceptions, the CC Crane, and RCA SuperRadio, both sound good with great performance. By the way, the RCA WAS the GE SuperRadio. I also like to pick up some of the vintage radios on EBay and other sites, plus occasionally at yard sales. Unless you are in the country and don't have a house full of gadgets, DX listening can be difficult, but not impossible. Best of luck, capttomconroy@jetbroadband.com
May 27, 2008 | RCA RP7887 High-Performance Super Radio
Black Meatal thing
The thing you are describing is a ferrite rod. It is the aerial that is used for LW and MW reception. The telescopic aerial on top is used for FM.
Providing it is a clean break and you haven't lost any parts of the ferrite rod, just tape it back together. It shouldn't have too great an effect on the reception.
Hope this helps,
Matt.
Mar 08, 2008 | Grundig G4000A FM/AM Radio
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
JVC AM FM CD DET FACE CAR STEREO Logo
467 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
