Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Transcend JetFlash V10 16GB USB
I cant format my flash drive due to drive is write protected, but I can’t see any physical switch…can you please help me remove or fix this problem..
please email me ramesh.sanga@ynail.com
  • rs958 Aug 12, 2008
    i cant format my flash drive due to drive is write protected, but I can’t see any physical switch…can someone please help me remove or fix this problem.. i need my flash drive badly.. thanks
    Scholar:
  • 93 Answers
Look for a "write-protect" key that is made physically on your USB FDD. Mine doesn't have one, but it should in most major new products. Switch it off.
Or, you can do it the soft-way. Right click on your UAB Flash Drive icon, then look for the Read-Only property, disable if it's enabled. or you will find that after right click click on properties
But according to my experiences, it seems that your USB FDD is locked physically
Posted on Aug 14, 2008
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When I send any folder always show me the disk is write protected remove the write protection or use another disk. for that I can't work properly. Please tell me how can I unprotected my usb flash. My...
This flash drive has a safety button located directly on it. PLEASE SWITCH THE BUTTON OVER, it will be easy to switch with the use of a nail on your finger. Once this is done, you will have access to the data on the flashjet card again. This is actually a safety feature that prevents you from accidently formatting the jetflash flash card. Thank you and have a great day.
Jan 21, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protect on my 8gb transcend jetflash
If you dont have any switch for 'write protection' in the USB body, then download the utility called 'Jet Flash Recovery Tool' from trancend web site. It could help you.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Cannot format diskrive because it is write protected
first open control panel then open computer management and than disk management than right click on pendrive option and format it
Jan 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My usb drive is write protected i cant format it pls help....
Have you tried doing it from another PC? If the same problem persists, look closely at your drive and check for a tiny switch that has a lock label on it- it maybe switched to the lock position. Most USB drives has this switch for write protection.
Jun 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cant format my transcend 2 gb pen drive it says write protected
do you see any switches on the side of it ? if so move it to the other position and try again.
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can't format my 2 gb transcend pen drive it saya write protect
Some usb drives/flash drives have a little switch that locks it and makes it read only to avoid accidentally losing important files. Try looking for a small switch somewhere on the case of the drive and switch it to the other position if you find it.
Go to the transcend site. In the support section, click drivers/downloads. Type in your model number or search for it. Mine was a Transcend 4GB JetFlash V10 drive. So the model number was TS4GJFV10. There will be a download called Recovery Tool. Get it. Run it. That's it.
P.S: use the global download link, its faster.
-TheIVth
Oct 11, 2008 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
319 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
