Toshiba e-studio 45
We tried to change the primary but the new primary that was installed causes black spots on the copy so we return the old one.
Yes, after cleaning the primary the copy is alright again. We'll try to check the HVT for the primary. Thanks for the help again. Hoping that the machine will be alright. Thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Did you fing the problem???
Posted on Oct 09, 2008
When I make copies, its doesn't come out clear and smudged.
Needs the drum unit cleaned. There is a green stick you can try pulling in and out on the front of that module. Also may need a developer change.
Jul 26, 2010 | Toshiba e-Studio 45 Black and White Copier
E-studio 45 is developing faint print generally, with some areas lighter in a mottled pattern. It has a new toner cartridge. Serviceman says he is not sure of the cause. He cleaned the inside, after...
I would call the service company and ask for another tech to look at the problem..... Yes the problem could be caused by the developer. I could also, be caused by the opc drum or the charge roller... Good Luck
Jun 11, 2010 | Toshiba e-Studio 45 Black and White Copier
Scan Color document by Toshiba E-Studio 45
E-studio 45 or E4500 is a black and white copier. Hence, it can only scan original document to black and white only. There are some copiers which have the color scan capability but not this one.
Feb 03, 2010 | Toshiba e-Studio 45 Black and White Copier
COPY QUALITY
Voids are most often caused by lack of sufficient developer, which needs to be changed by a technician. developer has metal beads in it to draw the toner and make a full (dense) copy or print. these beads wear out or "dump" which initially cause gritty prints, then washed out prints. hope this helps.
Jul 09, 2009 | Toshiba e-Studio 45 Black and White Copier
Toshiba e-studio 162d makes smudgy black margin
Hello sir; you do need a drum blade to replace at least.
May 11, 2009 | Toshiba 2860 Copier
Toshiba e-studio 45
sorry no manual, the seperation is the unit that is directly opposite the drum, it is a black unit with wires
Aug 09, 2008 | Office Equipment & Supplies
Toshiba e-studio 45
you must have to change primary
Aug 05, 2008 | Office Equipment & Supplies
Problem on Toshiba e-studio 45
I beleive that if there is a problem with the primary you will only get a blank copy not black.
the problem is most likely your Seperation ***'y or the drum.
1- either the sep/***'y is shorting out causing the paper to rise against the drum and putting too much toner output, or the drum has not been adjusted correctly. Did the tech adjust the new drum to the machine? there is a procedure you have to do everytime you change the drum.
Aug 04, 2008 | Office Equipment & Supplies
jasbo
jasbo
