Question about Intel Motherboard
RAID AND GCNL BOARD
CAN CONNECT TWO SATA HDD AND ENABLE RAID IN gcnl BOARD
  • 162 Answers
Jumper configurations not correct?
Posted on Aug 12, 2008
I am having asus K8S MX motherboard with amd2800+ processor. when connecting sata hdd it is dtecting in raid mode only .what is the solution to read the sata hdd in normal mode of booting.the raid is...
hi! are you having problem with sata booting system?pls try this solution,
first turn on your computer,and press del when the setup system appear try to look for advance settings or ferephiral setting and look for the sata setup,turn disable setup to enable or on.and press f10 to save setting,
hope this will turn your sata boot to normal mode,,,:)
Dec 07, 2010 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
May i use graphics card wid my 945 gcnl mother board plz help me
yes you can use graphic card such as (AGP) if your motherboard has AGP slot on the motherboard, before installing the graphic card, goto CMOS setup by pressing F2 or Del key while your system bootups and disable the onboard display in the setup and save it, then switch off your computer, then install the graphic card and start your computer hope your computer will works fine.
Jun 20, 2009 | Samsung (SC-152) Internal 52x CD-ROM Drive
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
We are delar & we give D 945 gcnl motherboard to
As a "dealer", you should return the motherboard to your "wholesaler" who supplied you with the motherboard.
Mar 23, 2009 | Intel D945GCL Motherboard
May i use graphics card wid intel 945 gcnl mother bord
no u can not use as intel comes with its integrated accelerator...i.e intel GMA
pls rate...cheerrsss...
Nov 23, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
I cant install my hdd sata
Under many cases, the default settings for additional onboard SATA/RAID controller could have been set to [Disabled] when delivered. This will cause the controller to stop its function completely. Suggestion: Please refer to your user’s manual for detailed description on how to enable onboard SATA/RAID controller via adjusting jumper or BIOS settings. Clean SATA cable with a couple cotton sticks lightly dipped into alcohol. If you sitll can not see the SATA drive from within the bios your onboard SATA/RAID controller is defective. Contact Asus tech M-F eastern time at: 812-282-2787. Tech will assign you a case number. Tech will than connect you to the RMA department for replacment/repair.
Jan 09, 2008 | ASUS K8V-MX Motherboard
Intel Motherboard Logo
19 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
