Question about HP LaserJet 3055 All-In-One Printer
Sacnner is not installed
Hi Dear,
I have hp 3055 all-in-one printer. Its Scanner has big issue.
I have installed all components on local pc.Now i am not able to scan docs from network.
so what are the proper steps to do so.
thanks
  • Kinjal Pathak Aug 12, 2008
    which network driver ? of HP printer or default windows driver?
    and if it is windows driver then it is installed.
    Thanks
  • 162 Answers
Did you install the network drivers on the network pc your trying to scan from?
Posted on Aug 12, 2008
  • Tony Budz
    Tony Budz Aug 12, 2008
    hp has 2 drivers the software prompts you to install, one is a network friendly driver, the other a standard driver on the local machine. The network driver goes on the pc that wants to access the printer over the network.
  • Tony Budz
    no the hp network driver is the one you want.
I am not able to scan the hp 3055 scanner. i got Twain compatability problem. so how can i solve the problem
Hi
Dear Remove your Hp driver for your Add/Remove Program and install again, may be your scanner  driver is corrupt.
For the driver please click hear select your Operating system and download the driver.
Good Luck
May 25, 2011 | HP LaserJet 3055 All-In-One Printer
Hi, the problem is i can not scan with the HP laserJet 3055 it prints via wireless with no problem but it says no set up on PC
You have to run the FULL setup on each machine for the scanner to work correctly. PLUG and play DOES NOT WORK very well, in that printing us the only function that works.... Go to HP.com and download and run the latest install software for your setup.
May 02, 2011 | HP LaserJet 3055 All-In-One Printer
How do I fix "Not
This error indicates that the scanner has not been linked to the desktop of the attached PC. Either launch the HP Toolbox and follow the scanner setup instructions, or if you do not have toolbox installed you will need to install the printer from the original disks that came with it.
Mar 29, 2011 | HP LaserJet 3055 All-In-One Printer
I want to set up my HP 3055 scanner so that it connects with PC
This is an interesting question ... Im thinking maybe even a trick question ...
You want your scanner to not connect with the PC? Don't plug the printer USB into the PC - vola - no connection. The scanner will scan without relying on the PC and the copy function is the same.
Mar 19, 2010 | HP LaserJet 3055 All-In-One Printer
Scanner Error 6 Turn Off Then On
Dear Sir,
Welcome to Fixya
1.Switch off the printer, then remove all cables connecting to the printer but just the power cable.
2.Then press and hold the *(start/symoble) and 5 button togather and turn on the printer,continue holding the button till you see "perment storage init" displayed and release the button.
3.Then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required.
I think it deffinately helps.If you have any problem regarding this issue leave a feedback we were happy to assist you
Have a Nice Day!
Oct 03, 2009 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
192 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
