Regards,
Tony
You gave me a 4TU and then take a refund on the answer I gave?
I requested refund on friday after I received another unsatisfactory response and prior to seeing your comment
OK, well fair enough. It happens. Sorry about your stroller. It happened to me too. I tore the heck out of it and saw for myself there was no real way to repair it. Take care. Tony
Good to hear they will replace it! That is some fine customer service. Can't beat that!
Hi, the side plastic tube cover that lifts the stroller to fold it damaged and it needs o be replaced..
Go to the nearest outlet for purchase of parts...
Take care..
Inspect the stroller's wheels and handle to identify the type of brake mechanism it has. If the device is equipped with wheel-mounted brake levers and swivel locks, use the toe of your shoe to activate these mechanisms. If your stroller is equipped with a handle-mounted brake lever, push down on the lever to engage the brakes. Some models also come equipped with a secondary-locking mechanism located on one of the rear crossbars; use the toe of your shoe to activate this feature. Lift the handle or press the tab securing the backrest in place, located on the upper edge of the backrest or on the crossbars securing the rear of the backrest to the frame. Grip the edges of the footrest, then lower the component by pushing it into the desired position. Pull back the stroller's canopy. Grip the stroller's handle and lift the device upward; if the stroller comes equipped with a safety button, press the button as you lift. Use the toe of your shoe to push on the stroller's hinges until the frame begins to fold. Pull the halves of the stroller's frame together until you have completely folded the device; if the stroller comes equipped with a locking latch, engage the latch to keep the halves from sliding apart.
Step 2
Step 3
Step 4
Audi Parts
No there is no damage to either of the plastic covers. They can be lifted manually but the mechanism will not lift them high enough to fold. I want to fix the mechanism which seems like it must be like a bike brake cable and somehow be adjustable to make more tension
