How do i fix the wrong disc error on my dvd player
Dvd message shows a wrong disc even after loading. why?
Posted on Oct 17, 2010
My Magnavox DVD reads disc error
QUICK ANSWER
A disc error may be due to having the wrong type of DVD in the player, having a dirty disc in the player or the disc having scratches or cracks. When it comes to the type of disc, it must be compatible with the DVD player for it to work.
FULL ANSWER
When this error occurs, pull the disc out of the player and look at the underside for smudges and fingerprints. If these are present, using a soft cloth to gently remove them generally solves the problem. Cracks and scratches generally require replacing the disc because they prevent it from working.
or try this link..if a popup comes up on the link just close it down.
Step by Step Guide to DVD CD or Game Disc Repair The DIY Video Editor
Dec 17, 2016 | Magnavox Televison & Video
Daenyx TV DVD Player Error
You either have a dirty optical pickup or a bad one in the unit--it reads the disc.
They do make a cleaning disc but that is only 50-50 chance(sometimes a disc gets put in with some kind of residue on it)
If bad the built in player will cost more to fix/replace than a cheap external unit connected to rear inputs in place of it--this is the real issue with combo units--usually cheaply made etc.
Apr 25, 2012 | Daenyx DN-26D 26-in. LCD HDTV/DVD Combo
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
I have tried several DVD discs in my Memorex DVD player and the same thing keeps occurring where it will say it is loading but then after a minute or so it says "Wrong Disc." It used to work fine...
I am not even sure I am allowed to tell you this but if you take out all the screws holding the cover in place so you can clean the lens inside with a cotton swab and a little bit of alcohol it will most likely fix your DVD player. MAKE SURE IT IS UNPLUGGED!!! If you dont UNPLUG it you can cause serious injury or death! I myself have fixed several read errors by doing so. Make sure to replace cover before plugging it back in.
Dec 13, 2010 | Memorex MVD2042 DVD Player
I keep getting wrong disc error on my Daenyk DVD player and do not understand why I have played these DVDs on it prior and no Problem
The reason the player keeps giving you wrong disc error is because the player is not reading the disc.
the reason is either the lens is dirty or weak.
To test if the lens is dirty, try to clean the lens with a lens cleaner and test the player DVD disc.
To fix it if the lens is weak, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
Take care
Jun 14, 2010 | Televison & Video
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
Disc not reading. toshiba dr420 dvd recorder.
Multiple problems with the DVD recorder one of them could be the lasers not reading correctly its software is messed up or there something wrong with this but to me it sounds more like the DVD recorder has a problem I've experienced this problem before not with this particular type of DVD recorder I fix the problem by unplugging the DVD player for about 20 seconds to a minute to give it a good reset.
Quick tip: most high Tech Device problems or unknown errors can be fixed by simple restart or reset hope this helps
Jul 28, 2009 | Toshiba DR420 DVD Recorder
Nexxtech N600 D wrong regional code
I have nexxt tech dvd 161-1000, I have the same prblem " Wrong Disc", I cleaned the lense, still same...Pls advice
Oct 15, 2007 | NexxTech N600D DVD Player
Wrong disc
same problem. it worked for a couple of weeks. now every disc I put it, it says loading... then wrong disc.
Oct 15, 2007 | Coby TFDVD6200 Portable DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
338 people viewed this question
Top Televison & Video Experts
