Question about Durabrand HT-3915 System
Replacement speakers I have one of the older surround sound systems where the power has a source and isnt connected to the subwoofer, and i was wondering if you have any replacement speakers for them. i have the sub, but all the other speakers were lost when i moved and i really liked the thing, it had pretty good bass for such a low price
  • Andrew Katsouris
    Andrew Katsouris May 02, 2016
    Are you wanting to replace the old speakers in home theater? Visit our site and take any brand according your choice.http://www.quantumav.co.uk/home-cinema/h...
You should be able to use any of the "bookshelf" speakers to replace the Front Left/Right and Rear Left/Right. I would go ahead and get a dedicated Center speaker. I bought a Pioneer center speaker and a pair of KLH 3-way bookshelf speakers at Radio Shack at low prices. I also bought a pair of Insignia 3-way bookshelf speakers. I put this all together with a Durabrand Home Theature system (dumping the satellite speakers). There is better range and a much fuller tone with these speakers versus the originals. Even if you hadn't lost the speakers, I would recommend this as a good upgrade.
Hope that helped.
Leonard
Posted on Aug 22, 2008
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
I have upgraded my surround system with Marantz SR5008 hd receiver replacing my SR780. I want to use the SR780 for a "audio only" music system in my living room (2 Bose speskers w/ powered subwoofer) and...
You could use a Speaker Switch. You can find an ione at: http://www.bestbuy.com/site/4-pair-stereo-speaker-selector/9746779.p;jsessionid=A65E902544159CF276BC147D7BE1F696.bbolsp-app02-185?id=1218166511087&skuId=9746779&st=categoryid$abcat0107032&cp=1&lp=1#tab=overview
Mar 01, 2014 | Kenwood VR615 Receiver
Speakers on cinema surround sound working on test only
More than likely the optical connection is defaulting to another source. The optical may have been intentionally assigned to another source and either needs to be reassigned or try switching the inputs on the unit until you hear sound...
Feb 04, 2014 | Logitech Z-5500 Audio Subwoofer Thx...
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
My subs sound choppy
Sounds like your sub is "clipping". Clipping is when your speaker is trying to pull more power than the power supply. (head unit, amp) If it sounds good at a low volume and choppy at high volume, supply it with more power. Bigger amp. If it sounds choppy all the time, push gently on the middle of the speaker. It should go back and forth smoothly. If it feels rough, you have blown the coil. Replacing the speaker is the fix for that.
Apr 14, 2010 | Sony Xplode P5 Turbo Subwoofers Car...
Best amplifier for bose 901 VI speakers
By all-in-one amplifier that handles the surround I think you mean all-in-one receiver or preamp. Amps are just big dumb muscular power supplies for speakers.
The source control and digital decoding could be handled by a modern AV receiver with multichannel analog outputs for driving separate amps or you could get a digital AV preamplifier/control unit functionally like this Adcom. Prepare for sticker shock.
http://hdtvdreams.com/Adcom-GTP-870HD-7.1-Multi-Channel-Processor/Preamplifier-GTP870HD.aspx
Understand that EACH PAIR of Bose 901's will require its own DEDICATED two channels of amplification AND someplace to jack in its Active Equalizer - between the line level source and the power amp.
Conventional speakers can probably run off the receiver's amplifiers since they don't/can't/must not have the Bose Active EQ in line with them.
Having a single pair of 901's plus a passive subwoofer or two in the same room for accurate 6- or 7.1 surround would require at least four stereo amps or some combination that adds up to 8 channels.
In my own system I have a Pioneer VSX-36TX Receiver (with 5 potential channels of amplification for Left, Right, Center, two Surrounds) doing light duty as the control and routing center but ONLY driving the Center (two Kenwood 777's) and Surround speakers (Bose 301's). I have a Carver 5-channel amp pushing the Bose 901 Front speakers (100Wx2), two dbx Subwoofers (110Wx1) and the Bose 301 Rear Surround speakers (60Wx1).
You could probably get by with a powerful 2-, 3- or 4-channel amplifier to push the 901's and subwoofer(s) as I did. It's the cheapest way out if you get a decent AV receiver. Once you set up the levels and delays the receiver does all the thinking and controlling for you.
Mar 18, 2009 | Bose 901 VI Main / Stereo Speaker
Rear speaker connection issue
OK, the fix for the missing rear speaker sound on the DELL WL6000 5.1 Surround Speaker System is relatively simple, just 7 simple steps (Verified by Dell at http://support2.jp.dell.com/docs/acc/P121646/multlang/srg/DAO/srg_dao.pdf..
First, power down everything. Second, disconnect the rear speaker and subwoofer from the power source and wait about 5 minutes. Third, be sure the power switch is off on subwoofer and the center speaker. Fourth, plug in the power for the subwoofer but DO NOT turn on the power yet. Fifth, plug in the rear speaker power cord. Sixth, turn on the swtich on the subwoofer (this is the start of the resync mode). Seventh, turn on the center speaker power and the system will change the rear speaker system LED from flashing blue to solid blue in 5-8 seconds. The surround system is functioning again. You may test this under sound in the Control Panel but I would prefer to use a modern music CD that has Dolby Digital Support for 5.1 sound or better. YOU WILL HEAR INSTANTLY THE SOUND DIFFERENCE WHEN THE REAR SPEAKERS ARE CONNECTED.
Nov 10, 2007 | Dell WL6000 Computer Speakers
Subwoofer not working
you have to reset the receiver, i had the same problem, works now, it's great, should be in the instruction booklet. I think it was, hold the power button while you disconnect it from the wall, not too clear but check the booklet in resetting system
Nov 01, 2006 | Kenwood VR-406 Receiver
Durabrand HT-3915 System Logo
344 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
