Question about Sony KP-51WS500 51" Rear Projection Television
Sony KP-51WS500 will not turn on
When I press the power button it sounds like the tv is turning on but the screen stays black. The red light flashes 3 times, then a short pause, then flashes 7 times very fast, then a longer pause & then flashes 6 times (slower than the 7 quick flashes....same speed as the initial 3 flashes) and then pauses & continues repeating the 6 flash cycle. Is this thing even worth attempting to fix? Many thanks for any help or advice I can get.
  • Sony Master
  • 8,617 Answers
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Posted on Aug 12, 2008
Screen turns red then shuts off
Sounds like a bad red projection tube, disconnect red tube socket and try again if tv stays on reconnect tube soket and adjust screen controls on front of tv under the front panel which you will have to remove to do any of this. There are six adjustment controls 3 are for focus for each color and 3 screen controls for each color. Look close at the black plastic control module should be labled R G B for focus and R G B for screens. Good Luck!
Mike
Apr 14, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony kp-51ws500...i turn it on and get a blue screen..can hear audio..but the standby/power light flashes then turns off.. count 8 flashes please help..thanks
Sounds like from your description the Blue CRT ( picture tube ) is shorted. I believe they are no linger available. If in doubt, I would call a service company to verify this.
Nov 21, 2009 | Sony KP-51WS500 51" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony projection TV when turned on a solid red line across screen when turned of a flash of red and until the tv is warmed up red ghost letters behind the normal black ones
Hi, you will have to replace the convergence circuit board on this unit. it is failing to calibrate the rgb stream.I'm sensing signal board failure as well.
Mar 08, 2009 | Sony KP-51WS500 51" Rear Projection...
Faint red curved lines on Sony KP 51ws500.Converged = no work???
Hi There!
This sounds like a typical problem related to a older CRT.
If you remove the front cover of the tv, you can then remove a wood panel. Behind this panel you will see a block (high voltage splitter) it will have 6 "knobs" on it, 3 will say focus, 3 will say screen.
They will also be labeled R - G - B
Put the tv on a blank input so you can see the lines clearly on a black screen  - Find the knob for red, and SLIGHTLY turn it down until the red lines disappear.
Dec 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Powers on then right back of light flashes 8 times
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
Mar 10, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
182 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
