Question about Krups XP4030 Espresso Machine
Steam Nozzle How do you get the steam nozzle to stay on and in place during the steaming operation?
I've only had it fly off once.  I think I didn't put it all the way on.  Also make sure you clean the nozzle every time you use the steamer.  Milk will clog the nozzle otherwise.  My maker is right beside the sink and I rinse the nozzle immediately after steaming milk.  I also run it through the dishwasher at least weekly.  (This isn't a substitute for immediate clearing of the nozzle.)   A clogged nozzle will always blow off the end.
Posted on Aug 20, 2008
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Why won't steam come through the nozzle
This could be because the end of the steam wand is blocked. Use a small sharp needle or similar to open up the holes in the nozzle and try again. If not you may need to remove the steam arm and clean it through. It could also be that the valve is failing to open when you operate it. Without knowing the make model you are unlikely to get a detailed answer to your problem
Dec 14, 2014 | Coffee Makers & Espresso Machines
Lavazza does not steam
put in steam nozzle something like a long needle or something similar.
Dec 07, 2013 | Lavazza Espresso Point Capsule Machine
Steam nozzle
Yes, it's OK to work without steam function. Actually, it is not a real hot steam. It just spray the water.
Oct 06, 2013 | LG Dryers
Little yellow steam cleaner wont work no steam coming out of nozzle
I have got a little yello steam cleaner there is no steam coming out of the nozzle wot should I do to be able to get this to work again if some one can help me please
May 06, 2012 | Vacuums
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
Water and steam?
no. probably a scale problem or a blockage. run another de-scale and open the steam nozzle during.
Sep 20, 2009 | Saeco Spidem Villa
Nozzle won't stay on steam tube
There should be two rubber pieces inside the threaded collar & cap that help produce a pressure fit onto the wand itself. There is a total of five plastic pieces on my steam wand excluding the wand itself on my Via Venezia by Saeco I purchased a year ago. Sounds to me like you lost one of you rubber gromets! Just my thoughts!
Dec 20, 2008 | Saeco VIA Venezia
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Krups XP4030 Espresso Machine Logo
472 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
