Question about Dell (E210882) Motherboard
Motherboard virus on board. The board start up but wont pass configuration
  • Woodshed Aug 21, 2008
    dell laptop inspiron 9300 bought in 2006 jan. so the warranty ran out...i have the same problem that is described.
  • Thomas Christopher
    Thomas Christopher May 11, 2010
    what happens then?
    Freeze, computer shuts down?
Well it sounds like the BIOS doesn't detect the hard drive any more. Viruses typically don't get transfered to the mother board/ BIOS itself. They usually are only on the OS. Unless someone flashed the BIOS with the wrong version or something. If that is the case it's either trashed or you need to find the correct patch to flash the BIOS. If this is not the case boot into the BIOS and configure it to see the hard drive.
Posted on Sep 04, 2008
Rebooting process keeps repeating itself halfway through start up
You might have some viruses and malware...
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 29, 2012 | Acer Aspire 5710 Series Laptop Motherboard...
When fixing the power cord socket on to the board it power the board but immediately I try to plug the auxllary onto the board to supply the processor it shut down the power.putting the two same time onto...
Motherboards can be configured to react to the application of AC power in several ways:
* always automatically start-up as soon as AC power is supplied;
* never automatically start-up when AC power is supplied;
* if on when the power stopped, come on;
if off when the power stopped, stay off.
Leave the auxiliary-connector NOT connected, if your computer works without it.
Enter BIOS SETUP, and change the 'POWER' settings, if you want the computer to stay "off" when AC power is restored.
Oct 22, 2010 | Biostar P4M900-M4 Motherboard
Need to unblock computer pass word
Clear the cmos memory, and re-configure the bios.
Mar 23, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How do I bypass my on board video card on my hp a6417c PC motherboard:MCP61PM-HM it died and i installed a new card but it wont let me get pass the initial bios selection screen
The old card has to be disabled in bios or some times you can do it from safe mode by uninstall. For bios settings depending on the PC it self you would have to start the pc and first screen that shows up will tell you how to access bios settings. In the settings there is an option to turn off on board video card. Hope this helps.
Jan 20, 2010 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Wont boot pass test sceen
Try resetting the factory defaults in your bios. (usually accessed by pressing Del, F1, F2, F10, or F12) Also make sure that all your conenctions are connected properly.
May 06, 2009 | HP Compaq Motherboard
How do i put my desktop board into configure mode. this is a new build and im trying to disable virus in bios
As the computer starts, keep pressing one of the following keys to get into the BIOS set-up: Delete, F2, space bar, or Escape. Often it tells you which key in a message at the bottom of the screen.
Mar 19, 2009 | Intel Computers & Internet
PC will not boot.
go to windows start menu and click on RUN. type in "msconfig'' without quotation marks and click enter. the computer will load the system configuration utility, on the general tab, select normal startup option, then click on the BOOT.INI tab the click on CHECK ALL BOOT PATHS,a dialog box will appear to tell you whether the windows boot directory is OK or not. if it displays that they are Okay, then there may be that a virus has affected those files. you ca also type in "sigverif" without quotation marks, on RUN to launch the windows file verification, click on start to check important windows files for their correct version. try restarting the computer. if your system still can boot, open the computer case to make sure that the hard drive, and RAM are connected correctly. if you still having problems, notify me.
Dec 03, 2008 | Northgate Athlon XP 400FSB Barebones...
CMOS Error 0193
The security device plugs into the left front of the MB as viewed from the front. It is approximately 1.5" x 2 inches in size. they sometimes come loose form the socket when a system is moved. Open the case and see if it is there and loose. If completely gone, then you need to contact your MB supplier for either the device, a new board or a factory reprogram of the board to disable the missing device.
Oct 12, 2008 | IBM NetVista PC Desktop
MY ACER ASPIRE 3002LCIPC LAPTOP WILL NO PROCESS PASS THE WINDOWS STARTUP
Unfortunately your in a state where you need to
1. boot into a dos based application and run a virus remover.
2. slave that drive to a clean master that's protected with virus software
3. blow the drive away and start over.
sorry
t
Aug 28, 2008 | Acer Aspire 3002LCi Notebook
System wont work with new Mptherbard
Boot into the BIOS and look at the settings. Is the correct hard drive selected as the boot device? Are the IDE settings correct? Does it have an SATA or PATA hard drive?
When you change motherboards it's a good idea to write down the BIOS settings of the old board before you remove it. Probably too late for that now.
Nov 20, 2007 | Computers & Internet
Dell (E210882) Motherboard Logo
59 people viewed this question
Alun Cox
