Password i would like to create a password to my computer so that other people can not use it i'm using windows vista home edition
  • Anonymous Feb 10, 2009
    i need a password that i can only use.to do everything
  • 162 Answers
Try setting the master password in the bios, push f2 when you power up the computer and look for the password option there. Vista isn't the best for security, lock out the system by setting the system or hdd password and nobody can ever use it.
Posted on Aug 12, 2008
  • 477 Answers
When you logged in on windows push ctrl + alt + del and click creat password/change password. or go to controll panel -> user accounts ->set/creat password.
SOURCE:
How do I lock my computer from my child without risking me not being able to get back in please? In fact I don't know how to lock my computer in any event.
You can create a Vista password recovery disk to reset your password. Follow this 5 easy steps:
1. Enter a computer that can link to Internet. Search "windows password recovery tool" in Google. Download and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to recover vista password.
5. Now login Windows and set a new password.
Mar 13, 2011 | Microsoft Windows Vista Home Basic Edition
Tip
Windows Password Key 8.0 is considered as the best tool to reset local...
You can change a Windows User Account password that is on any Windows computer from any other Windows computer regardless of whether the User Account is on a workstation, a stand-alone server, or a Windows domain controller. Additionally, it makes no difference whether the password being changed from a workstation, a stand-alone server, or a Windows domain controller. This is true for any NT 4.0, W2K, XP Pro and Windows Server 2003 computer.
To change a user's password at the command prompt, log on as an administrator and type:
net user danielp * /domain
(This is only an example, use your own username)
When you are prompted to type a password for the user, type the new password, not the existing password. After you type the new password, the system prompts you to retype the password to confirm. The password is now changed.
Alternatively, you can type the following command:
net user danielp 123456 /domain
When you do so, the password changes without prompting you again. This command also enables you to change passwords in a batch file.
Note: If you type these commands on a member server or workstation and you don't add the /domain switch, the command will be performed on the local SAM and NOT on the DC SAM.
on Apr 28, 2010 | Microsoft Windows XP Professional SP2
I forgot my password how can i get it back thanks
Are you using window? If so:
Locate and download a program called "OPHCRACK"
Insert disc and restart computer:
Set your bios to start from the CD:
Just press F8 or whatever the screen says for the BIOS settings and/or options..
Set the boot option order to CD first rather than second or third.
The program will run and it will start to recover the passwords(s)
Jan 25, 2011 | Microsoft Windows? Vista Home Premium...
I reset my administrative password to Windows Vista, now I can't log in.
The step-by-step guideline:
Step1: Download Windows Password Recovery Tool and install it.
Step2: Burn the ISO image file onto a blank CD/DVD.
Step3: Boot up your Windows PC by the bootable burned CD/DVD in minutes.
Step4: Remove the forgot Windows password on the operation interface and logon PC without password.
Oct 18, 2010 | Computers & Internet
What tool do you recommend if you forget your VISTA password?
For recovering Windows logon Password safely, I recommend software program Windows Password Seeker. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to remove Windows logon Password. I wrote it to a Usb memory card. Booting up and clearing my password within just 4 minutes. You can Search Windows Password Seeker or download it from:http://www.passwordseeker.com
Aug 28, 2010 | Microsoft Windows Vista Ultimate Edition
Hi i forgot my windows vista password and i want to log on to my computer ...how can i log on to my computer... i have windows vista cd ...plz tell me the exact procedure now...Thanks
If you want to keep your data safe, then do not use that Windows recovery CD as it will wipe out all the data in a partition like C:. Well, by relying on a password recovery software, you can easily reset Windows Administrator login password easily and gain access to your locked computer. Hope it helps. Regards.
Aug 19, 2010 | Microsoft Windows Vista Ultimate Edition
How to unlock a dell windows XP home adition laptop when turning on laptop?
Do not worry, we can use dell password recovery tool to complete this task. Windows Password Rescuer is designed for resetting dell Windows 7/vista/XP password. What you should do is prepare a bootable CD/DVD or USB drive and a computer you have access to. Follow four steps help you reset dell windows password without lose anything:
Note: You also can use Windows Password Rescuer to reset Windows 2008/2003/2000 local or domain password easily by these steps on dell computer.
Step 1: Download and install Windows Password Rescuer on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk. You just need to burn it to a blank CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your dell laptop or dell computer, and set the computer boot from the password recovery disk by BIOS setting. If you have trouble in BIOS setting, refer to:
How to set computer boot from CD/DVD.
How to set computer boot from USB drive.
Step 4: After boot from the password recovery disk, Windows Password Rescuer will start up and display a friendly operating window. Then you can reset whichever account password of your dell computer just by a few clicks.
You also can use Windows Password Rescuer to create a new user with administrator privileges for your dell OEM Windows without login. With this new user, you can login your dell computer directly and access control panel to reset other user password.
Jul 11, 2010 | Dell Microsoft Windows XP Home Edition
Forgot password
If you did not create a password reset disk you need a technician to do this for you. If there is another user on the computer you can remove the password from the control panel using there account.
Feb 23, 2010 | Microsoft Windows Vista Ultimate Edition
Windows vista password reset
Login as "Administrator" or "administrator" as the user name and the password will be either blank or "password". Then press "OK" and you should be in. Then you can go to the Users control panel & reset your password.
Apr 08, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
I forgot my password on my new Acer Laptop
Ophcrack, a freeware password recovery program, can create a boot CD which will discern your password in a very short time by booting with the CD you create from a working computer.
It is available HERE.
Dec 26, 2007 | Microsoft Windows Vista Ultimate Edition
Open Questions:
Computers & Internet Logo
85 people viewed this question
Ekse
Alun Cox
