Question about Motorola Mobility RAZR V3
Insert Sim Card Error
The error goes away and the phone works fine if I apply pressure on the back plate.
  • Anonymous Dec 30, 2008
    "insert sim" message appears.
    Brigadier General:
  • 7,752 Answers
Well the back plate made need to be tighten or replace the housing
Posted on Aug 21, 2008
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Hi i have a samsung SCH-W339 mobile the problem is i have inserted many sim cards but it displays limited service instead of displaying the sim name and i cant make outgoing calls neither i recieve...
1. Your sim card is not in the right position. Take out your battery and your sim card. Make sure it is in the right position. Also make sure no dust or dirt where the sim card goes. Put the sim card back in your phone and battery. Turn it on. See if the insert sim card goes away.
2. If it goes not, then you will need a new sim card. Go to your local service provider store to get a new one.
Mar 25, 2011 | Cell Phones
Sim card
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
Smartchip rejected error
Turn off the phone. Take the battery and Sim Card out. Make sure there is no dust or dirt of where the Sim Card goes. Blow air (from your mouth) of where the Sim Card goes. Sometimes rubbing a soft pencil eraser on the Sim Card contact points can help. Then place the Sim Card back in the phone. Make sure it is in the right position; copper contacts facing downward. Put the battery back in your phone. Turn it on, and see if the smartchip rejected goes away.
If not you may need to contact your Phone Provider’s Tech Support to troubleshoot and confirm that you may need a PUK reset code to register or you may need a new Sim Card, as they do fail from time to time.
Oct 02, 2009 | Nokia 2610 Cellular Phone
I am getting a random error message on my Motorola RAZR V3 Celluar phone. It says I should insert the SIM. The message goes away when I reboot, but it reappears. Can anyone help?
Remove the back cover, battery and SIM card. Wipe the SIM and the pins where the SIM card is inserted with a cloth if u can. Reinsert simcard, battery and back cover.
Aug 24, 2009 | Motorola Mobility RAZR V3
Configuration error message on sony ericsson cell phone
maybe your phone has a simlock, if so you have to insert the sim card of the provider that your phone requires.
Jun 22, 2009 | Sony Ericsson W710i Cellular Phone
Phone sporadiacally displays "insert sim card" even though it has a sim card inside (never been taken out). Switching off the phone and switching it on again was what i did. However recently my...
it could be that the contacts between the phone and the sim card are dirty and therefore you will get the error code. take the battery out and remove the sim card take a q-tip with some rubbing alchohol and clean the contact on sim card and the phone itself make sure not to use alot of alchohol. let them air dry then re-insert the sim and battery this should do the trick. the error warning should go away and the phone will be abale to receive the contact info from gthe sim card.. please rate this
Sep 20, 2008 | Cell Phones
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Motorola Mobility RAZR V3 Logo
218 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
