Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Protron LCD TV Circuit board
Do you still have a circuit board available for this TV? I think mine has imploded. Thanks
  • Orlando Resendez Sep 09, 2008
    On the Protron PLT-26, mine went dark with no sound all at once, like it was on a timer circuit to go bad at that exact time. I checked with the service centers locally and they can't fix this brand of TV since no parts are available. I wouldn't recommend buying an off-brand in the future.
  • alliechester Mar 17, 2009
    The tv was on and all of a sudden the tv just went off and never came back on again. I had a service technican come out to the home to perform a diagnostic test. I found out that I need a new circuit board and you can not get the part(s) for the 32" Protron Crystal Display LCD. I have only had this LCD for 2 years and its no GOOD!!!! What can I do? Having problems contacting the manufacturer to honor the warranty.........
  • Protron Master
  • 5,568 Answers
Just posted this elsewhere:
 I checked and found the Protron name belong(s) or (ed) to Spectroniq and neither of the two websites are up anymore.
Also, I could probably make a zapped supply work again but you do not know what might have been damaged downstream from it and that is a good possibility; the damage may be much deeper than it appears since many of the integrated circuits used in modern equipment don't tolerate hundred (or thousand) volt spikes and without a working supply, there is little chance of diagnosing it unless a service department has a few lab-type power supplies and can simulate the failed original supply.
If you do find anyone who has stock on assemblies for this TV, you may find more than one part number on the board. If it is a number that seems to be under clear lacquer, it is likely only the bare board number. If it seems to be stamped on or has a label with a number on it, this is going to be the whole part number for the 'stuffed' board.
I can't help you with this one but I would suggest, especially if you live in a lightning-prone area to consider installing a 'whole house' surge protector. They do cost a couple of hundred US dollars plus installation charges, but the established companies even include an insurance policy that covers $10,000-25,000 in damages. If you own your home, it's your decision and I cannot imagine any landlord would object to having you install one at your own expense.
Posted on Sep 28, 2008
Sound works < but no picture
Proton LCD TV, Hi, most LCD's and Plasma's have a cold/ hot circuit and the board for video and audio are the same usually it's a main board but before going through all that check to be sure that it's not a setting or volume adjustment. older model proton TV's exchange the main board these usually go bad IU would search any auction sites for a similar model with a broken screen and take out the needed parts for this fix, otherwise your better of getting a more updated LCD TV good thing is that they are way cheaper now
Feb 26, 2014 | Protron PLTV-32 Television
Protron 32 inch tv sounds work,but black screen
Possible that the back light circuit has failed. You need to check on the invertor circuit , it can be due to failure of the power supply to the unit, if so trace back to the power supply and check for open fusible resisitors or fuse.
If power is absent check on the SMPS unit.
If there is power then th drive or the transformer is a suspect.
Nov 05, 2011 | Protron PLTV3250 32 in. LCD Television
My Protron 32" tv went blank, is there a circuit
no breaker .most likely a fuse firs check the out let with a lamp to Se if it work,s be for you take the TV apart.
Dec 23, 2010 | Protron PLTV-32 Television
Looking for a remote control that replaces the protron pltv-3750. I want to make sure it controls tings on the tv like video source, pip, swap, volume, etc...Aside from the Logitech Harmony 360 LCD Remote...
Try fixing your old remote control.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 11, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
My protron tv pltv-32c has no picture but has sound, if you change channels the picture will flash on for about 1 second
Hi.
If there is sound but no picture, screen is completely dark and the picture is occasionally flashing, then the fault is likely a faulty inverter. In some case a faulty controller board or a defective PSU can cause the same problem.
I summarized the problem here:My LCD TV has sound but no picture.
I posted general procedure to test inverter, PSU and controller board on LCD here : How to test an LCD TV or monitor PSU and inverter.
If screen is not dark, but has blacklight or noise things are different. In that case check connection cables first. Parts that may be defective are main controller board, terminal circuit and tuner board.
Protron parts are available using the link below. Ensure that parts are compatible with your model before purchasing.
ShopJimmy - Protron Parts.
Regards.
May 15, 2010 | Televison & Video
Turn tv on no sound
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Jan 06, 2010 | Protron PLTV-4250 42 in. LCD Television
Complicated Question about repairing circuit board
Broken LCD panel does not affect circuit board behind that panel.
Make sure that other TV should be same model (KDL-40W4100) to swap boards / LCD panel because each model has its special designed boards and cannot be used in different model (if chassis is same, few boards can be used)
Apr 29, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No Picture (power indicator does not light up)
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
Mar 31, 2008 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-3250 fried
remove pwr board--inspect and you will find a heavy current diode which has eatin its solder pad area--if diode checks ok,repair it's connection.Install board and hook back up.Check for shorts in circuit.Cross fingers and plug her up------good luck
Jan 26, 2008 | Protron PLTV3250 32 in. LCD Television
Circuit Board
if you didn't damage it to bad you could take a wire and use it as a jumper to cross over the traces you drill thru.
Dec 06, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
344 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
