Question about Yamaha DSP-A1000 5-Channel Amplifier
Problem with Yamaha Amplifier 361
I have purchased Bose Acoustimass 6 series along with Yamaha 361 amp have observed that all the five speakers are not playing on the amp at the same time, both the front right and left speakers don't play when the centre and two Left Right rear sourround speakers play and vice versa.please let me know if there is a setting issue??
    Novelist:
    Champion:
  • 236 Answers
Volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Posted on Aug 13, 2008
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
How do i hook up bose accustimass speaker to my radio?
Acoustimass speakers need to be driven by a Hi-Fi amp/receiver or AV receiver. So the thing that's driving them needs to be an amplifier.
Unless your radio is also an amplifier then the radio and the Bose speakers are not directly compatible. There's no suitable output on the radio that generates the correct signal in sufficient power.
Sep 07, 2014 | Bose Acoustimass 5 III System
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
Sep 30, 2012 | Bose Acoustimass 3 Series IV - 2.1-channel...
Which model of amplifier will match the Bose AM 10 series4
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
I hope this helps - good luck
Sep 14, 2010 | Bose Acoustimass 10 Series IV Home...
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
How do i use my ipod to play through my 12 year old Bose Acoustimass series 5 system
You don't connect an Ipod directly to any unpowered speakers since they need an amplifier between them and your source. Presumably, your speakers already have an amp source? Then what you need to know is how to connect the Ipod to the amp. Without specifics, I can only offer general advice. Get an adapter for the Ipod headphone it to make it compatible with either an RCA input or a headphone jack.
Nov 27, 2009 | Bose Acoustimass 15 System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Dec 22, 2008 | Bose 901 VI Main / Stereo Speaker
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Yamaha DSP-A1000 5-Channel Amplifier Logo
141 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
