Question about D-Link DCS-G900 Network Camera
D-Link DCS-G900 Network Camera setup
Ive been given a dlink dcs g900 ip camera but have no software for it, is it possable to configure this without the software you would get with it or do i need to find drivers etc ive connected the camera with a standard cat 5 cable and tryed to ping it but get nothing also it doesnt seem to show up in my network when it connected to my wireless router any help would be great?
  • 659 Answers
Http://www.dlink.com/products/?pid=270
go here and on the right under support resources select application.
Posted on Aug 12, 2008
SOURCE:
How to recover corrupted firmware for IP camera DCS-5220?
http://support.dlink.com/ProductInfo.aspx?m=DCS-5220
Go to this site and download the drivers
Then
Uninstall old drivers and install new ones
Jan 06, 2017 | D-Link DCS-5220 Network Camera
What is ip default dcs-3110 network camera?
Please follow this process for IP Address:-
http://setuprouter.com/router/dlink/dcs-3110/login.htm
Dec 29, 2010 | D-Link Dcs-3110 Megapixel Camera DCS-3110...
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
Webcam driver
Go to manufacturers websites or www.driverguide.com and download the driver from there
Jul 03, 2009 | D-Link DCS-950G Network Camera
I have a DCS-G900 camara from d-link system,I need to know how to get to work the unit i need the software and manual thanks Gianni
http://support.dlink.com/products/view.asp?productid=DCS-G900.This is the d-link page for everthing related to your camera.this is a fixya vote blue(4)RICHARDM69
Dec 18, 2008 | D-Link DCS-G900 Network Camera
Cannot factory reset DLink DCS-G900
i had the same problem and it was frustrating at first. You have to access your router and find the start ip address and the range and make sure dhcp is enabled. then plug the camera into one of the lan ports using the cable provided and plug the other end into the camera. then refresh the list of wireless clients in the router. Also if using a pre n router make sure that the broadcast is not mixed and is set to g mode. Only a g router will work or a router with g set to broadcast. i couldn't get the camera to work until i changed this setting. Anyways getting back to what i was talking about. When you see the list of clients you will see the camera listed on the client list. Write down the ip address example (192.168.1.108) and then on the computer (make sure you have another cable plugged into another lan port on the router and plugged into your computer) go into the dlink setup wizard. Press the search button the camera will appear on the list. Then click on the wizard and wait. It will say that the settings do not match there is an ip conflict or something to that matter do you want to change the settings click change settings and put the ip that the router configured. subnet mask is 255.255.255.0 and put the default gateway of the router which is usually 192.168.0.1 on most dlink routers but on the linksys i was using it was 192.168.1.1. After changing these settings it will let you into the camera configuration and after that you can unplug the cable and wait a minute or two. the green light should start blinking showing that the camera is connected to the router. Bingo your all done your camera is back to normal wireless function. You might have to unplug and reset the camera. If you have more than one camera make sure you unplug all the other camera's before configuring the first one. This will prevent any ip conflcts. Hope this helps you.
Sep 22, 2008 | D-Link DCS-G900 Network Camera
DCS-1000w through Dlink DIR-655 router
These cameras are touchy. Hold the reset button on the back in for about 20-30 seconds. Bring up the CD software you got with the camera, it should spot the camera right off and you can configure. That seems to be the only way I can communicate with this model. After setup, then browsers, etc seem to work fine. I would also download the latest Firmware and update.
Apr 12, 2008 | D-Link DCS-1000W Personal Web Camera
D-Link DCS-G900 Network Camera Logo
423 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
