Concept flip down monitor # cm 1520
Stopped getting power is there a fuse in the unit itself?
  • 2,071 Answers
Yes there is a fuse inside the unit,just open your unit and locate the fuse.If you aready change the fuse still not working then the problem go deeper.First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner. This TV monitor is small enough to take to a repair shop find a good one.You probably have to pay $50 - $75 dollars up..Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 12, 2008
I turn on dell vostro 1520 and screen is blank. Screen shows to activity at all. On status bar between keyboard and screen POWER, CAP LOCK AND + indicator lights are lit solid. The NUM LOCK indicator is...
Attach to external monitor, if it works, there is a fuse that is blown near the video output cable. Not big enough for a novice to fix.
If not shown on external, it is a dead lcd, or bad solder ball issue. Quite common on those models.
Fuse details may be shown on my webblog. "Getting In Too Deep" Google it. Then search for Dell - it should come up in the list.
Jun 23, 2014 | Dell Vostro 1520 Notebook
Auto monitor will not turn on
it sounds like you are having a transformer failure of the unit itself. these parts are not even repaired by the manufacturer. unless you are an electronic whiz i think your only solution is to replace the monitor.
May 26, 2012 | Computers & Internet
My car tv does not turn on and all the fuses are good
Since you are sure about the fuse why not see if the monitor unit gets the power or if there is a line break. If the power does come to the main board in the set, check if the regulator in the front end power is supplying the supply to the main IC.
Check the signal from the player to the monitor, if possible test on your TV with an extended cable.
However if the power and the signals are normal, then it is possible that the monitor IC has failed.decide with the cost and availability if reasonable.
hope this helps.
Aug 19, 2010 | Concept P1020 Car DVD Player
Kv-mr 9 inch widescreen flip down monitor only shows grey screen
Mine was doing the same thing. i checked all the fuse connections and found 1 was bad and that solved my problem. good luck
May 19, 2009 | JVC KV-MR9000 9" Widescreen Monitor
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Monitor not working
DUE TO THE FACT THE TV UNIT IS FIXED TO THE INTERIOR OF THE CAR AND WILL ABSORB THE IMPACT AS WELL. ITS HIGHLY POSSIBLE THE UNIT WAS DAMAGED IN THE ACCIDENT, DO SOME BASIC TROUBLESHOOTING , CHECK THE HARNESS FOR DAMAGE, PLUGS AND FUSES BEFORE U FINALLY TOSS IT
Aug 26, 2008 | T-View T1501S 15 in. Car Monitor
The screen turns blue durring a movie
It sounds like it is an internal problem. Could be bad ribbon connection or something else that is loose. How long have you owned the unit for?
Thanks,
Lee
Aug 05, 2008 | Concept CM-1100DR 11.2 in. Car Monitor
CLARION VRX935VD PARTS LIST
Well,it seems you have couple problems there.
About the ribbon cable the part number is 039-2144-00
And about the monitor flips up and down easily,you will need to replace the complete slide mech assy;part number 948-0646-00
you can order it from pacparts.com
Apr 19, 2008 | Clarion VRX935VD Car DVD Player
No picture
get a hold of concept via there web site and they should be able to help you with a local repair place or at least you can send it to them and have it repaired.
Apr 13, 2008 | Concept CM-1100DR 11.2 in. Car Monitor
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
Electro Med Services...
