LG Xtremo LM-M1040, and over the last few months, when listening to music, the system turns it self off. To rectify I have to disconnect the powert from the wall socket for a number of seconds then plug it back in again, and it works. Now it will not turn back on.
  • olbaldy Sep 06, 2008
    Have the same unit with the same problem. Found that running the unit without the right hand (when facing it) side panel, it will run continuously (12 hours). Adding extra heat did not bring the problem on. Re-soldered the power supply board with no joy. Replaced the power supply PTC fuse for good measure (TH901) as this can eventually fail.
  • Anonymous Apr 04, 2009
    I have the LG LM M1040 stereo system and it has the same problem, I just recently opened it up and replaced the stock fan with a larger 12cm PC fan that runs on 12v (the same as the stock fan) and nothing happens the doesn't spin or anything, I have tested the fan separately and it still works, is it possible that the fan isn't getting any power if not, where is a place where I can solder on some extra wires and power the fan?
I suspect that this is a design problem guys. The fan in this unit is fine, it only turns on when volume is turned up high & fan speed varies with volume.
The problem I think is the STRX6759 on power board. The aluminium heatsink is too small to dissipate enough of the heat from the device. You will burn yourself touching it!!
The STRX6759, whilst I can't find the datasheet on the component it looks to be a voltage regulator with a thermal cut out. When it gets too hot (probably after an hour) it cuts itself off to protect itself until it has cooled enough. Then you need to turn unit off & then on again to reset.
I am modifying a friends unit with bigger heatsink but damaged a coil. If anyone can kindly supply me with coil. Part Number: LF902 please contact me: ian873 (at) gmail.com (in Sydney, Australia)
Posted on Apr 04, 2010
  • ian873 Jan 23, 2014
    As a follow-up. Managed to replace the coil. However in relation to the above problem I can report that I made a large heatsink from sheet steel which I bolted onto the existing (but too small) heatsink to the regulator. This fixed the problem. The extra surface area of the added heatsink resulted in more heat disipated, more rapidly per unit of time. In a nut-shell, no more thermal power-cut off. Problem solved :-)
My LG LM-M1040 mini hifi system will no longer read discs. It has been sitting in the same place since purchase 2yrs ago and has only been used a few times. can you help
The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Apr 26, 2010 | Audio Players & Recorders
Hi my archos 3 vision is frozen, how do I get it going again
Hi
My Archos 1 Vision. Wont play a particular music file. It has played it amazingly fine since i bought it 3 months ago. It was connected to my computer charging for a while, then i turned my system off so it was off for a while.
Wanted to listen to a few songs before bed,turned it on,selected Music,Scrolled down to the file i wanted,Went to select a song.........FROZEN! I can turn it off but the same thing happens everytime i go to select something from this file
Please help i need music on my travels ;-)
Feb 19, 2010 | Archos 2 Vision MP3 Player
No more sound on my lg kp500.theres a message on my phone which said that i cant listen the music on bgm mode... How can i reactivate the sound?
Preess the multi-tasking button (the middle one) and a screen should pop up listing "Home" "Top Menu" and "Audio Player". Tap Audio Player, tap "Use As" then the last on the list should say "Shut down" tap that and it should shut down the BGM.
Sep 20, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
When I turn my unit on, it will turn itself off in a few second.
have you checked to see if any of your speakers are shorted out? the rt2870does have a self protection system in place such that if theres too much power being drawn from the system or if a short occurs it will shut off. or the switch that powers the sub may have gone bad so try disconnecting the sub and see if that helps. i have the same system and i had the same problem and i had to replace the onboard sub-woofer power switch.
Mar 15, 2009 | Audio Players & Recorders
Chan needs help :|
simply format the player ...in xp using ..format option..if dat dusnt wrk reset the player (theres a reset pin provided.look for it !!) and the prob sud be solved...such probs occur due to fragments in memory and can be reset very easily as suggested above..lemme know if ur prob wuz solved .
Apr 30, 2008 | Philips GoGear SA178 MP3 Player
666 people viewed this question
 Grubhead
Grubhead
