Question about Nikon Cameras
My cammra wont take pics and the lenze wont go down, i droped into the sand, got all the sand off of it though.
    Master:
    Sergeant:
  • 398 Answers
Dropped digital cameras are usually dead digital cameras. No matter how careful you are sand and dust can get inside and raise havoc with the internals.
Posted on Aug 12, 2008
How do you delete unwanted pics
go to photos and tap the album in the cammra roll press the arrow and you can now select pics to delete them..
you can delete the pics not in cammera roll by pluging your iphone to itunes then go to settings on your phone to unsync the folder with the pics or deseclect photos if theres buttons aviable .. also set a new folder for your pics if you have photos you want to keep to make that simple
Dec 23, 2011 | Apple iPhone4 4G iPhone 4
We need user manual of Lenze ac 7800 ., if any one could help us with the same ., contact on nmbabrakar@yahoo.com
http://src.lenze.com/lenze-bibliothek/Lenze-Archiv/AA%20-%20Inverter%20Drives/7xxx/TB_7811-7818_EN.pdf
Mar 13, 2010 | Lenze AC Tech Lenze 8100 AC Drive Inverter
The tape is jammed. it is half way out of the cammra, but it wont open or go back down.
try to pull out u r casset rebon slowlly if you fill too hard then cut the rebon, then resque your casset 1st. after that slowly clean the reamining rebon. batter you vist service center becouse there is a chance og damaged of ur CAM head. Be carefull. Good luck.
Jan 30, 2010 | Sony Handycam CCD-TRV12 Camcorder
Fe-310, only used a few times, kept protected, one
Short answer - yes.
Manufacturers have become very good at making products that are reliable for exactly 1 year.
Usually it's small components that have a deffinate shelf life.
I would first check that you are using the correct battery for it. Even if it looks like it takes standard AA's - they often will only work for original spec rechargable blocks.
If this does not solve it - write a letter to Olympus saying how dissapointed you are with their product.
They may offer you a good deal on a repair hopefully.
Unfortunately Sony and HP are even worse - HP and lexmark printers now stop working after a period of time - telling you to buy more ink - even though you still have plenty.
Oct 01, 2009 | Olympus FE-310 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Sand
use a vacume to **** up most of the grit. DO NOT USE COMPRESED AIR. if the lens is making crunchy noises. basically all the internal gears are done. sony wont touch cams that have been droped in water or sand. try the vacume thouh it has worked before.
Jun 04, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
How do I clean the interior of the lenz for Powershot A640
Its a big job, If your petty handy, You have to start from the back of the camera, Remove rear cover,Then front cover, Next lcd Display unit, Hopefully your haven\'t put the battery\'s in the camera for a while because the flash has high voltage in it, if you have, You must discharge first, them take circuit board out,Then lens assy, Now the fun part, You have to take the lens apart from the back also, Like I said its a big job, Better when you get this far into the camera you just replace the lens, with a used one form a diff camera (same model )
Feb 25, 2009 | Canon PowerShot A640 Digital Camera
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
Cameras Logo
24 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
