Can not turn on printer - Office Equipment & Supplies
  • Anonymous Sep 12, 2008
    Plugged adapter in and checked main plug and fuse no life at all from printer
  • 659 Answers
Try a different plugin and make sure that the adaptor for the printer is completely in the unit.
Posted on Aug 12, 2008
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
When I go to print, a box pops up and says "Service Error 5100". It says to turn my printer off and then back on. This does not fix it. I lost my manual so I have no idea what to do. Thanks!
Service Error 5100 means that something is blocking the ink carts or head.. with printer off move the ink cartridges in the well by hand all the way to the middle of the printer then turn the printer on.
  1. turn printer off
  2. turn printer on
  3. remove both carts
  4. turn printer off
  5. turn printer on
  6. replace carts
  7. turn off
  8. turn on
that should clear up the issue if not you need to try replacing the cartridges or removing and replacing the inkwell (place where the carts fit in)
Mar 21, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. for epson stylus r 290
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on.
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
Samsung 1640 printer how to resat
first turn off printer and plug off cabel power
1. open printer
2. look at IC EEPROM 93c66WP
3. connect no 1 and 4 pin IC 93c66WP
4. turn on printer, wait until printer shown green lamp, it mean calibration finish
5. turn off printer again
6. disconect no1 & 4 pin ic 93c66WP.
7. turn on again, and printer ready again
Dec 04, 2010 | Samsung ML-1640 Monochrome Laser Printer
Turn the printer off and delete all print jobs. Open the printer cover and remove any paper from inside the printer and turn the printer back on. two red light segnul and not print .
Oct 06, 2010 | Epson TM-T60 Printer
Printer keeps saying can not communcate checked and repug cords
Try turning off printer, unplug printer, turn off computer, plug in printer, turn on computer, turn on printer- in that order. It will all reset.
Dec 20, 2009 | Lexmark X2600 InkJet Printer
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
Turning my printer from offline to online
Check your printer connections.
Go to printer folder and clean all pending jobs.
Turn off your printer
Turn off your computer
Turn on your computer
Turn on yor printer
Check the status fo the printer must be "ready" (at the printer folder)
If not replace the printer cable.
Is still the problem remain, uninstall an reinstall the printer.
Oct 08, 2008 | Office Equipment & Supplies
159 people viewed this question
k24674
