Question about Car Audio & Video
Ford sound 2000 radio (locked out)
Have a ford sound 2000 c radio. 3 dashes not flashing. Can't enter the code that i have. Thanks
Hi, leave set powered on till flashing you can then enter code, cheers, noel.
Posted on Aug 13, 2008
I have a ford radio and i have lost the keycode.
if this radio has a M000000 number then i can help but if a V000000 number then its a ford agent .but if it is a C number code then 3367 could be the number ,press the first preset button 3 times to show 3 ,second button 3 times to show 3 and so on then press preset no5 to enter the code into the radio
Mar 04, 2013 | Ford Escort Cars & Trucks
Tip
How to enter a Ford Radio Code
To enter the security code and get your radio up and running again follow these instructions;
Turn the radio on and the display will show ' CODE - - - -
Press preset button [ 1 ] repeatedly to get the first digit on the display
Press preset button [ 2 ] repeatedly for the second digit
Press preset button [ 3 ] repeatedly for the third digit
Press preset button [ 4 ] repeatedly for the fourth digit
To enter the code press the [ 5 ] key to accept.
The set should now operate.
If you have lost the code to your radio
Remove the radio from the dash and find the serial number of the radio which is on a label on the case.
For European Ford Radios you can get your code here for £3.50 using the serial number of the radio.
I have used this site numerous times and can confidently recommend the service as fast and accurate. This site is for European Fords only.
Ford dealerships charge over £20 for this so there is a considerable saving in using this service.
For USA Fords you will need to contact your local Ford Dealership with the VIN number of your car. Expect to pay $30 - $50.
Hope this Tip helps. Please do leave a vote for it. Many Thanks.
on Nov 05, 2010 | Car Audio & Video
I have just put a new battery in my 1992 3.1i8 BMW and consequently reset the radio. It has locked in 3 dashes and I can't enter any numbers in. Any help would be greatly appreciated!
If you do not have the book for the radio, I believe there is a trick to entering the code. Its not just using the numbers. I think you have to hold another button down while entering the code or use the station up down button to enter the code. Try hitting all the buttons one at a time and see if that enters anything on the desplay.
Jan 30, 2013 | Cars & Trucks
Keycode for Ford Sound 2000 radio
hi this will be 770 for your code...hope this helps please vote thanks
May 22, 2010 | Ford Car Audio & Video
Wot do i do after entering my code on a 5000 rds
Radio should start straight away.
If it is the same as the 3000 series , the numbers are entered as numbers of times you push sequential keys. ie: code 1579 , push number 1 once, push number 2 five times, push number 3 seven times and push number 4 nine times.
If the display is flashing " ERR " you will need to leave the ignition on until it stops flashing and the display reads " CODE" . ( it can take up to an hour)
Hope this helps.
Apr 08, 2010 | 2000 Ford Focus
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
I need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
  1. If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
  2. The code number for the radio is advised to you on the enclosed CODE CARD.
  3. To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
  4. Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
  5. If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
  1. If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
  2. The code number for the radio is given on the enclosed CODE CARD.
  3. Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
  4. Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
  5. If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
Dec 17, 2009 | 1999 Mercedes-Benz E-Class
FORD 2007 RDS KEY CODE RADIO CASSETE PLAYER CODE ERROR
You can not enter the code. The radio is locked.
Oct 10, 2008 | Car Audio & Video
How to unlock my radio (5000 RDS ford) from the LOCK 10
if locked 10 appears:
ensure the radio is off.press and hold preset 6 and switch radio on keeping 6 pressed.the display should change after a few seconds and u can then enter the pin code but i beleive u only get 2 or 3 attempts so make sure u have correct pin or it will need to be sent away to be unlocked
robbie
Jun 28, 2008 | 2003 Ford Focus
Car Audio & Video Logo
1,453 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
