Question about GE JEB1095 Convection/Microwave Oven
Microwave won't heat and mkes a sparking sound 8-11-08
I put some mashed potatoes in the microwave and heated them up for my son; then I went to heat up another plate of potatoes and they didn't cook at all. Then I thought ok I will try it again and then when I turned it back on it started to make a awful noise like sparking and looked like some sparks flying around.
  • jblomberg Aug 18, 2008
    GE came out and they told me it was the magnetron which was still under warranty but I still got charged a fortune for labor and service call. I wasn't to happy believe me.
    Jeri
  • GE Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
If you need further help, please reply back with your brand and model number so we can help you.
Posted on Aug 18, 2008
How to heat cooked potatoes for mashed potatoes
hi Judy.
Put in the large pot as you peel and slice so they don't turn brown. Be sure water covers the potatoes by 2 inches, on medium-high heat and bring to a boil. Reduce to medium-low heat, cook the potatoes for 20 minutes until the potatoes are soft and fork tender. Turn off the heat, and drain well in a colander.24 Nov 2015
Make Ahead Mashed Potatoes Reheated 5 Ways - Delicious Table
https://www.delicioustable.com/make-ahead-mashed-potatoes-reheated-5-ways/
if you want to know more go to this link.
How to heat cooked potatoes for mashed potatoes Google Search
Nov 23, 2017 | Microwave Ovens
Why is my microwave so erratic?
The internal controller may be defective.
Feb 06, 2015 | In Microwave Ovens
How do I freeze cooked mashed potatoes?
Place them in a plastic container, close it, label and let go. I've never tried freezing mashed potatoes so can't testify as to how it holds up. But this is basically how I freeze everything else that comes my way.
Sep 27, 2014 | Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
Jenn air microwave makes zapping sound and won't heat food
Possible bad inverter board (power) and or the Magnetron which does the main heating.
Oct 31, 2012 | Jenn-Air Microwave Ovens
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
We have a new 24"Dacor
The service manual is here and the parts list is here.
That mesh is the door screen which prevents microwave leakage.
It must be intact or replaced, or a fire hazard exists.
You can order Dacor parts by part number from the Pros here.
Feb 26, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Sweet potatoe caught fire in my microwve
the magnatron super heated the paper combined with what we in the industry call super combust your micro should be ok to use just keep it clean and if you use toweling wraP it around rather than cover
Apr 21, 2010 | Amana ACO1860 Microwave Oven
Will tin foil in the microwave ruin it completely? The microwave turned off after my son mircowaved a potato wrapped in tin foil.
You should always put a spoon in a cup of liquid that you heat in a microwave oven.
The microwave with a potato wrapped in tin foil is like operating the oven with nothing in it! If the microwave was spotlessly clean then your in trouble.
1 put a cup of cold water in the microwave and set for 5 minutes. if the water boils then your lucky if it cold then go and buy a new microwave and stop your childs allowance for a fortnight.
One might ask the question how old is your child and should they be using such a machine unsupervised!
Nov 05, 2009 | Microwave Ovens
My LG over the range microwave doesn't heat any more
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
That said, you can get free estimates on the cost of a repair but you should also consider a replacement which may be a better option for you.
What they do not tell you about over the stove microwaves is that they are constantly deteriorating due to the steam, oil, and other cooking fumes from the stove below. As a result, their life expectancy is definitely diminished.
Aug 19, 2009 | Microwave Ovens
GE JEB1095 Convection/Microwave Oven Logo
110 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
