Question about Epson Stylus CX4200 All-In-One InkJet Printer
Paper Jam This printer was working fine. I got new ink cartriges and replaced them according to the instructions because I got the message they were low(even though I knew there was some ink left in the old ones) and then all of a sudden the paper started feeding crooked. It makes all the right noises but feeds crooked and then tells me the paper is jamming so I should clear the path and try again, but it's not jammed, it's just not going through because it's feeding incorrectly.
  • 446 Answers
There maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Posted on Aug 12, 2008
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
My workforce WF-3540 displays "PAPER JAM". I can find no jam
This sounds weird but I will post it since is solved this problem for me. Despite following all the instructions I could not get rid of the "paper jam" message on my WF3540 . In desperation I tried changing the yellow ink cartridge (which was low) and after the printer went through all its "new cartridge" routine - lo and behold the paper jam message was gone and the printer worked!
Sep 25, 2013 | Epson Workforce 1100 InkJet Plotter...
Epson Artisan 835. Just set up. Printed fine. Tried to eject DVD/CD tray. Did not eject. I turned off unit. Turned back on. Now constantly says I have a paper jam when there is none. Cannot use.
Hi. I Have an Epson printer too and become to send the paper jam error when there not a paper jam on the printer. Check the ink cartrige bay with the printer off. The ink cartrige bay have to stay all the way to the right. If not push carefully to the right. Start again the printer and see what happens. This cause in certain ocassions the paper jam error. I hope this tip can help.
Aug 13, 2013 | Office Equipment & Supplies
My HP Officejet 5615 All-in -One shows "Papierstau" (paper jam) though there is no sheet or piece of paper in it.It then also sometimes shows first "aligning cartriges" and then "paper jam" and then...
Unplug your printer. Then wait 40 seconds and plug it back in. Check if you have enough ink in your cartridges.
If all else fails replace ink cartridges.
They make paper that has alcohol on them and you can run it through your printer to clean those sensors. Just hit Cltrl and P at the same time.
May 18, 2017 | HP Officejet 5615...
I keep getting error message C000 which tells me to shut down the printer and restart it. How do I fix this. Thanks
1) Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
2) If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
3) Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Jan 29, 2011 | Canon Office Equipment & Supplies
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and replug...no luck!
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Epson Stylus CX4200 All-In-One InkJet Printer Logo
346 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
