Question about Kustom Deep End 200HD 200 Watt Bass Amp Head
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have inspected everything had it taken in and they could not find any problems what so ever the cab is fine works with other head please explain to me what is wrong with my head
  • Kustom Master
  • 5,603 Answers
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
Posted on May 06, 2011
SOURCE:
I have behringer bx4500 bass head that hums and the fan on the back doesnt come on. What causes this to happen?
THere can be various causes, none of which will be user serviceable. Contact Behringer for the nearest service center. Here is the link-
Behringer Bugera Portal Starin Distributing
Sep 25, 2016 | Behringer 450 Watt Bass Amp Head BX4500H
How do i connect a Behringer 1202 mixer to a Behringer B215D Powered speaker
Looks like both units accept 1/4" jack & I think the 1202 is unbalance out, so just use a standard screened mono (i.e. 2 pole "TS") jack to jack lead & you should be fine. Good Luck! :-)
Jul 28, 2014 | Behringer B215D Powered Speaker (550 Watts...
I have a crate 16 channel mixer and when i power it on i cant usually get sound through the channels when i hook up a mike sometimes the low z input works and sometimes not. the regular line in for the mic...
If you have already spray cleaned the pots and switches then the problem is almost surely bad solder connections on the board. This happens often if unit travels a lot with no case. Resolder all pots, switches and jacks and check copper trace for breakage at these places. In case of broken trace hard wire across breakage.
May 11, 2017 | Kustom Deep End 200HD 200 Watt Bass Amp...
Powering on and off
Like as not, Behringer is a disposable brand once the warranty (which does not cover wearing parts like pots and faders which wear out quickly and are not worth replacing due to the design in most cases)
We normally sell behringer kit if it still works just before warranty expires.
Feb 13, 2014 | Behringer Eurolive B205D Active 150-Watt...
Monitors not audible with Behringer 1680S
Assuming you're trying to power the monitors from this unit as well as the mains.....Confirm that the amp switch is in the middle position which splits the internal amps....one for main and one for monitors. Output A would power the monitors.... B would power the mains.
Aug 26, 2012 | Behringer PMP1680S Europower 10-Channel...
How do you switch the behringer 3000 to bridged mode,what settings do you use to get 1200 watts out of it.
Well... you probably won't like this, but here is some info: In bridged mode, a different Speakon to speaker cable is required from only the B... it is wired differently and you can only use one of the plugs. The speaker or speaker system CANNOT be less than 8 ohms in bridged mode... this precludes using speakers in parallel or multiple speakers that are less than 16 ohm impedance... such speakers are NOT commonly available as most are either 4 or 8 ohm. There is a slide switch for bridged mode on the face of the mixer. Next thing you won't like... The 1200 Watts specification is PEAK power, NOT RMS... You can get 400 watts RMS per side USING 4 ohm speakers. If you use 8 ohm speakers, each of those will get 200 watts. I use this mixer myself and ALSO repair them. The voltage swing at the outputs is about +/-60 volts MAX (peak). This is about 40 volts RMS by the time the circuit LOSSES are taken into account. Across a 4 ohm speaker you get 10 amps times the 40 volts or 400 watts. Across an 8 ohm you get 5 amps or 200 watts. The voltage rails in the switching amp are +/-70 volts DC so these are reasonable values. Bridged mode just uses both sides of the amp driven in opposite directions for higher voltage out BUT you have to use no less than a single 8 ohm speaker so there is NO advantage to bridged mode power wise. IF YOU NEED more power, use extra speakers from an additonal amp driven by the 1/4 TRS mains output jacks OR use additonal POWERED speakers driven from the same jacks. Please read my tip about the hazard regarding the SLEEVE of the cahnnel A cable when using Speakon to 1/4 plug cables being the HOT and the tip being the cold for channel A. Ground the sleeve accidentally and goodbye channel A amp...
May 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My behringer pmp 3000 has litle power i thing is 3000 or how much power it haveit? I put 2 speaker only ,,,, thankyou
The unit should drive 400 Watts RMS into a 4 ohm load per side.
The amount of sound power you get will VASTLY depend on speaker efficiency. You would likely use at least 15 inch speakers with the unit.
Aug 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Finding a way to hook this up
Send main 1 out to your Crown. Jump Mon send to PWR am insert.
Mar 11, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Kustom Deep End 200HD 200 Watt Bass Amp Head Logo
152 people viewed this question
Top Kustom Music Experts
Michial Gueffroy
guitar zan
Are you a Kustom Music Expert? Answer questions, earn points and help others
