Question about Polaroid Televison & Video
After loading the screen indicates no disc - Polaroid Televison & Video
  • woodyarnold Aug 14, 2008
    As I stated before, I cleaned the lens, the disc then played fine,but, after reinstalling the same disc it indicated no disc.I tried other discs sometimes they would play fine, other times indicated no disc. iNCONSISTENT.
  • 1,029 Answers
How long have you used the dvd?you can change the lase lens instead if after cleaning thres no improvement
Posted on Aug 14, 2008
  • 6,487 Answers
This can be a problem already with your players lens, because after you clean it and work fine again but now you have problem again, I may suggest you to take this to a repair center near you hopefully they can just replace the lens...
Hope that helps........
    Master:
  • 521 Answers
Lens problem.try to clean it manually from the top with dry tissue.if still the problem, open the unit by removing the screws and then carefully without moving the position of lens clean it internally.it will be ok.
Posted on Aug 12, 2008
  • tech expert12 Aug 14, 2008
    open the upper cover of the device and adjust the alignment of the lens by tightining or loosening the screws which holds the cd above the lens.it shows no disc sometimes because the alignment is not proper.so aligning it properly will solve your problem for sure.thanks
  • 2,071 Answers
If not locked by a region code,then it needs to clean the lens..
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
  • 1 more comment
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    If your dvd not playing the originals dvd,the problem is in the optics lens maybe accumulated dirt and dust need to clean ,use a special cleaner i have site below that you can order online..
    http://www.amazon.com/Maxell-DVD-LC-DVD-...
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 20, 2008
    did the solutions from all of us experts solved your problem if not
    then let us know the current updates so all the fixya experts can
    assist you further.
  • LORETO LACARON
    LORETO LACARON Aug 26, 2008
    What is the brand name and model number...
Dvd will not load disc
If the unit indicates no disc or disc not read it is likely a dirty or bad optical pickup in the player.
May 04, 2012 | Dynex DX-LDVD22-10A 22 in. HD-Ready LCD TV
Sony dvd player doesn't read disc says no disc when loaded
This would indicate the laser pickup assembly is the problem, try a DVD cleaning kit and follow instructions, if no change, far cheaper to replace the stereo.
Mar 17, 2012 | Televison & Video
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
When I put my disc in it loads...then it displays
Wrong disc usually indicates a problem with the lens mechanism of the DVD player. It can be dust/lint blocking the path of the laser there by preventing it from reading the disc or it can be a mechanical problem like lens out of alignment. You can attempt to clean the lens using a lens cleaner CD/DVD with liquid and see if it resolves the issue(you can get one for as low as 5$). Perform a dry cleaning first(without the liquid) and then with liquid(two drops on the brushes of the lens cleaner DVD that pop-up after the dry cleaning run. If it doesn't resolve the issue then you may have to get the lens mechanism checked by a qualified technician. You can search the fixya repair directory to find one in your area.
http://www.fixya.com/repair
Oct 12, 2009 | TruTech TT320
Ps3 wont read any game/dvd
there is nothing you can do yourself. the ps3 BD drive is bad and needs to be replaced. your only choice is to replace the drive yourself or call sony.
also are you able to play games from the hard drive? if so your BD drive is defective.
May 31, 2009 | Sony Playstation 3 (PS3) Console
Apex adv #3800
Clean the eye... try another disc, apex usually pretty robust unit. Glass eye near center spindle, clear alcohol, swab gently.
Loading indicates unit doesn't see the disc..
Mar 27, 2009 | Kenwood DV-6050 Multi-disc DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
My PS3 Games wont show up in the games list
Return under warranty.
the blu ray laser will have been slightly overheated and as a result will need to be replaced.
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Loading screen on my PS2 .....
Does it do anything after that? (like show a picture of a disk?) Also listen closely to the drive for any "Clicks" "Ticking" or scrapiting noises. This could indicate a problem with your console.
Jul 29, 2007 | Sony PlayStation 2 (PS2) Console
Disc loads but player displays No Disc message
If you cleanred the optics and this didnt help then you did all you can do without more test equipment. Your player might need an focus or tracking offset alighnment or a focus or tracking gain alighnment or the unit could have a defective laser. Only by connecting it up to test equipment will a tech be able to tell.
Aug 24, 2006 | JVC XV-FA900BK DVD Player
Televison & Video Logo
55 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
