Question about Motorola Mobility RAZR V3i Cellular Phone
I cannot make or receive calls - airline mode????
I have a circle with a line thru it, where the bars are to be?
How do I get it off airline mode?
  • llorine Aug 13, 2008
    Thank you for the help. I have got to keep the gkids away from my phone!!
    Problem Solver:
  • 11 Answers
Go into your setting and there sould be the opion for airplane mode click it and turn off.
sincerly
http://wowwireless.ecarter.com
Posted on Aug 13, 2008
What is the telephone number for United Airlines?
Really? You got on a computer, found this site, and figured out how to put in a question, but can't Google "telephone number for United Airlines"? 1-800-864-8331
Jul 11, 2016 | Computers & Internet
Can not hear anything from my mini ipad
make sure the sound is turned up. Barring that, look in your settings area to make sure it's not in airline or airplane mode.
Jul 20, 2014 | Apple iPad Tablets & eReaders
WATER COMING INTO SINK THRU AIRLINE
Take apart the solinoid that controls the water going to the drain during the pump out cycle you probably have a tooth pick stuck in the solinoid valve, hope this helps.
Sep 08, 2012 | GE Dishwashers
Water coming into sink from dihwasher air line
there is a drain line that attaches to the sink. if water coming up in sink then sink drain is probably clogged.
What is the iphone lock symbol with circle arrow around it?
Orientation lock. This means that the screen will not switch between portrait and landscape mode when you rotate the phone.
To enable/disable orientation lock:
  1. Double-press the home key
  2. Slide the icon bar to the right
  3. Press the (lock)/(circle arrow) logo to toggle the lock mode
Mar 30, 2011 | Apple iPhone Smartphone
Temp display on mirror is in cellcius and wont switch to farenheight
Press the mirror power button, the one with the circle and the vertical bar thru it. It cycles thru ON/OFF, F and C.
Jul 02, 2010 | 2002 Chevrolet TrailBlazer
No sound on my Mac
Try clicking on the circle with the line through it. Sounds like it is muted.
Oct 20, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
3gal. aircompressor - craftsman model #921153101
This problem is not uncommon with small compressors and the inexpensive plastic regulators they use nowadays. The one surefire way to stop it is ti install in in-line valve before the regulator outlet, even if it involves the double ended & threaded brass soupler so they both fit on. This way you can just turn the handles across the line effectively shutting off air flow. I have two pancake compressors and ended up doing the very thing.
Then when time comes to hook up a hose and tool, just switch the handle back and you have air.
Sirwriter
Apr 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
AXU4100 Manual or help
On a Motorola AXU Series (including the 4100):
1. To unlock, press the “D” button for about a second or until the circle is gone. The circle with the line thru is the keyboard lock indicator;
2. To change channel, you need to press either the arrow left or right in Normal Mode;
3. To change PL (assigned to a channel), don’t think this can be done by the user
4. To change Ch. 1 from 464.500 MHz (PL-67.0) to 463.525 (PL-136.5), don’t think this can also be done by the user.
Even the built-in Programming Mode Parameters do not have this option to change assigned frequencies and PLs. An external programming software using a PC may or may not allow this.
These radios came pre-loaded with its channels assigned with specific frequencies/PLs. As used in a Motorola AXU411, they are:
Channel Frequency PL
1 464.500 67.0
2 464.500 77.0
3 464.500 88.5
4 464.500 179.9
5 464.500 None
6 464.550 67.0
7 464.550 82.5
8 464.550 94.8
9 464.550 179.9
10 464.550 None
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 24, 2007 | Motorola AXU4100 (10 Channels) 2-Way Radio
Colored bars across page
I would try changing the ink cartridges and if you don't have a new set at least take out the ones you have and reseat. Also check Epson's site for new drivers. Try printing from a different program.
Mar 28, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Motorola Mobility RAZR V3i Cellular Phone Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
