My install disk wont work in the hard drive - Office Equipment & Supplies
  • 162 Answers
Download drivers from mfg website.
Posted on Aug 12, 2008
SOURCE:
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
My hitachi 1tb xl1000 drive wont read my files and is saying that the drive is not formatted. What is this?
It means that there is no operating system installed on your hard drive and so it will not work until you add one. Buy a windows xp disk or an operating system that you wish to use and put the disk in the cd/dvd rom. Reboot the pc to get it to pick up on the disk in the drive and then follow the prompts to install an operating system.
Mar 21, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My 320gb external hard drive has stopped working. I have used it alot with my laptop, but i hadnt used it for about a month. when i plugged it in it said it needs to install device driver software, but it...
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If the problem persists, either:
* the USB cable is damaged,
* inside the enclosure, the disk-drive is not functioning
(although the lamp indicates that it is getting electrical power)
* inside the enclosure, the USB-to-disk-drive adapter has failed.
If the warranty is still valid, W.D. will replace it, at no cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program; buy a new unit from their web-site, and you can get a discount, as a previous customer.
Or, open the enclosure, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, to see if it is working at all.
Or, buy a new, compatible, disk-drive, and mount it into the enclosure, to make a "new" external disk-drive.
Oct 29, 2010 | Western Digital 320GB MyBook External USB...
External hard disk wont work
You really need to provide more info. Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Apr 04, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a dell gx240 im trying o make it boot and it just wont.i have used maxblast5 and 4 ive tried xp os and it wont install the hardrvives are used from an old computer,wht can i do to stsrtthe install
If your using the Dell recovery disk that came with the computer, chance are it wont install unless your using an identical hard drive as the original that was installed in it. You may need a new full OS disk. If you still have the original drive, may be able to ghost or clone the old drive and get it to work. There are quite a few programs for copying (ghosting, cloning) a complete hard drive image onto a new drive.
Dec 05, 2009 | Dell OptiPlex GX260 PC Desktop
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
Dell latitude wont turn on
If you hear the hard disk clicking, most likely you have a faulty hard drive.
Go into the BIOS configuration and see if the BIOS has detected the hard disk, if not this means the hard disk is faulty or the disk controller is faulty.
To determine if the hard disk is faulty, remove the hard disk and connect it to an US hard disk adapter and plug it into a working computer's USB port. If this computer sees this as an external hard disk/external storage device and you can open the various folders and files then the hard drive is OK.
If the hard drive is not detected then it is faulty and you need a replacement hard disk and Windows needs to be installed on this drive to get the Dell operating again.
Jul 18, 2009 | Dell Latitude 100L Notebook
Laptop screen wont work.
Assuming you don't have 2 drives installed in your laptop then you will need to get a windows system disk or install disk and boot up with this in the laptop to load windows whatever into your hard drive and set your laptop up to run on the new drive. Here is Microsoft's tutorial on how to install and set up windows:http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps you.
Mar 29, 2009 | Acer Aspire 5315 Notebook
Open Questions:
87 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
