Question about Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Failing install of PCI SATA Drive
SONY VAIO PCV-RZ44G Pentium 4 2.8ghz
My original ATA HDD crashed and I am attempting to install PCI SATA card and 500GB seagate SATA.
PCI card seems to boot but HDD won't recognize. SInce I was able to use DiskWizard to partition the new SATA drive on an old IBM k2 333mhz 6GB with XP installed thot I was golden. But on install attemp in Sony, the Recovery disks say "no drive" and fresh XP Pro install says partitions are not XP compatible, even tho XP install said the same thing when I also made a partition with XP install during an earlier install attempt. Seems like it's a conflict of some kind???? MOBO is apparently Asus P45D VX. Orignial Desk Top came as MCE2004
Any ideas?????
  • YMii Aug 12, 2008
    Thanks for such a quick answer.
    Have done that and PCI card loads and lists hard drive id in it's bios, it's when I get past that point HD shows up in XP install as "unknown" or "no drive' with recovery disks install attempt.
  • Anonymous Mar 30, 2014
    SUSPECT VIRUS COMPUTER QUIT WORKING NORMALLY WHEN TRIED TO REBOOT WITH SONY INSTALL DISK STILL GOT BLUE SD\CREEN OF DEATH ERROR MESSAGES
    COULD NOT FIX WITHOUT ERASING AND FORMATTING BOTH DISKS. nOW SONY OP SYS DISK WILL NOT RUN OR INSTALL, CAN NOT INTALL WINDOWS OP SYS. DISK EITHER, DRVS NOT RECOGNIZED BY WIN XP INSTALL DISK SCREEN SHOWS FOUR SECTONS ON SCREEN BUT XP DISK SAYS IT CAN NOT INSTAL ON OR RECOGNIZE THE DISK. nOTHING WILL WORK THE DISKS MAY BE CLEAN NOW OF VIRUS BUT NTHIING WILL INSTALL ON THEM.(I DIDUSE OTHER SOFTWRE TO CLEAN DISKS )wHAT CAN I DO? DO I HAVE TO BUY NEW HDD TO INSTALL NEW XP OP SYS? I CAN SEE NO ALTERNATIVE!
  • 3,940 Answers
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Posted on Aug 12, 2008
  • IQUIT Aug 12, 2008
    That is exacly the situation I described.
    The drive is seen in BIOS, but is not seen by the XP installation because the driver for the controller is NOT NATIVE to Windows XP. If you watch during the XP install, there is a prompt to press F6 for a controller driver. This was orignally designed for SCSI hard drive controllers, but now is used for SATA controllers or any other HDD controller whose driver is not native to XP
    Many computer manufacturers add controller drivers to their XP CD's (a process known as slipstreaming) to avoid the need for a floppy drive and loading the driver manually. Since you are ADDING a PCI card, then you'll need to load a driver.
    In XP loading a Controller driver is a legacy process. By design this can only be done for a CD NON-NATIVE driver from a floppy diak drive as noted in my last replay.
    In Vista, any data source can be used, but XP it is either the installation CD or a Floppy The files have to be in the root of the floppy, not in a folder). You can even have the drivers on the floppy and have the diskette in A: BEFORE YOU BOOT to the CD. If you do that, XP will look to the flopy without the F6 prompt, making the install a bit easier.
I want to upgrade the mother board in my Vaio PCV-RZ44G Desktop so that I can run Windows 8. What board forms are compatible and is an Intel I3 or I5 CPU better?
You would be better off applying the money to a new computer. You are opening "Pandora's Box" . You will end up with a old case with ALL new components. That may or may not work, A.K.A., "pain and heartache".
Jan 07, 2013 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
I want to download all info from my desktop and motherboard into mylaptop
Hi Eva!
If your desktop is crashed, then you will need to verify if its internal hard drive is still working, and then conect it using an USB/SATA/IDE adapter to your Laptop. This is one: http://www.sataadapter.com/SATA-IDE-ATA-66-ATA-100-ATA-133-COMBO-ADAPTER/sata-ide-adapter-usb-hard-drive-sata-drive.html
If the problem with your desktop is with its hard drive, then... you need to take your computer to its manufacturer technnical service center.
Sep 27, 2012 | Sony VAIO PCV-W600G PC Desktop
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    How can i connect a seagate barracuda hard drive to a sony vaio desktop pcv-rz22g? i'm installing an a additional hard drive but can't seem to find a sata connector on the motherboard, so there's no way...
    You can't find a SATA connector because there isn't one. That computer was built before SATA drives were widely available. You will need a Serial ATA controller PCI card to connect your SATA drive to your computer, such as here:
    http://www.compusa.com/applications/category/category_slc.asp?CatId=1455&name=Serial-ATA-Controllers&
    Make sure it is a PCI card and NOT a PCI-Express (or PCI-e) card, as your computer doesn't have any PCI-Express slots either. Here's an example of what you need:
    http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=3501402&CatId=1455
    Also, the Barracuda is probably a 3.0 Gbps drive, but will only run at the slower 1.5 Gbps speeds from the PCI interface cards. Again, it's an age thing. That computer was a top dog in it's day.
    Dec 20, 2010 | Sony VAIO Digital Studio PCV-RZ22G PC...
    Replacement for Sony Vaio optical disk
    Your computer is an older pentium 4 PC. As such it uses ATA / IDE - EIDE drives. These days stores sell SATA drives but IDE drives are still VERY COMMON. You can find tons of them on eBay or your local computer store (for much more than eBay). The original drive has a 24x CD reader, 8x CD-r writer and a 4x DVD reader. It does not write DVDs. You can buy any ATA/IDE drive you like and now you can probably afford a DVD burner too.
    Apr 23, 2010 | Sony VAIO Digital Studio PCV-RX670...
    No sound with a Sony VAIO pcv-RZ44G after installing new webcam (Logitech Sphere/Orb MP) and Skype
    not much info.....Do you get a picture??
    You must set up webcam in Windows under Control panel sound,speech,audio devices.
    Picture is setup in Windows also in control panel / printers, scanners / scanners and cameras.
    Mar 24, 2010 | Sony VAIO PCV-RZ44G PC Desktop
    Sony vaio 640 hard drive
    You can use any brand you like, as long as it matches the type of plug setup as the original hard drive i.e. PATA (IDE), or SATA (Serial ATA)
    Mar 08, 2010 | Sony VAIO Digital Studio PCV-RX640 PC...
    Can i install a 1TB drive with a IDE-SATA in a Sony Vaio PCV RS14
    If the motherboard does not come with built in Sata plugs then you will need a PCI adapter. The only way to know for sure it to check with the manufacture. Most newer ones allow for it.
    Thanks Live-Tech 1-888-361-8511
    http://www.mylive-tech.com
    Jan 29, 2010 | Sony VAIO PCV-RS144 PC Desktop
    How to connect a sata cable to pcv-rs420
    There are no SATA headers on the motherboard. (Connector on motherboard is a Header)
    You have 1 AGP slot for a graphics card, and 3 PCI slots, (White in color)
    You can however, buy and install a SATA adapter card in one of those PCI slots. (The computer comes with a modem adapter card in one, of the PCI slots, therefore you may have two PCI slots that aren't being used)
    This is Sony Support, and the main page for the Vaio PCV-RS420 Desktop PC Computer,
    http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRS420
    Under the heading - Specs, you can click on - Marketing Specifications
    (PCVRS420)
    This tells you the Expansion Slots you have, ( 1 AGP, and 3 PCI)
    (Plus other specifications)
    In case you do not have the User Manual anymore, you can download it by clicking on - VAIO User Guide - under the Manuals heading.
    (Shows how to open the computer case, among other information)
    This is an example of a SATA adapter card with internal SATA headers, and external e-SATA ports,
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4350464&CatId=508
    Any additional questions about this, and I'm right here.
    Regards joecoolvette
    Dec 12, 2009 | Sony VAIO Digital Studio PCV-RS420 PC...
    Bigger hard drive
    I'm not sure if the motherboard supports SATA drives, so your best bet is getting any IDE (ATA) hard drive. It's up to you which kind you want. I've always been partial to Western Digital and Seagate.
    If you are running Windows XP then you shouldn't have a problem with having a larger hard drive, I know Windows 2000 had some issues with them that required registery editing.
    Dec 11, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
    Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop Logo
    410 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
