Question about Craftsman 17026 Wet/Dry Vacuum
Craftsman table saw
I was using my table saw (Craftsman Model # 137.228210). When I turned the power on to make a cut I had the piece of wood touching the blade. The power turned on, but the blade didn't turn. Before I got the wood away from the blade the power cut off.
The table saw has a circuit breaker built in, and I tried to reset it with no luck. Do these table saws have a fuse or something? I could never get the saw to come back on. I checked the blade, and it is turning freely. I do have power to the plug as well.
  • blmm5786 Sep 05, 2008
    I am having the same problem. I checked the fuse to the house and the extension cord and still have power. I hit the reset button, but it still won't come back on.
    When you get an answer, let me know.
  • ljk187 Sep 06, 2008
    I just had the same problem after ripping about 25 feet of 2x6 boards on a used, but new to me tablesaw. Seems to be a common problem with these, and I haven't been able to get any answers for sears. I'll post if I can work it out.
Alright, I have fixed mine, so maybe the same thing will work for two as well. I actually have a slightly different model (113.298341) but I imagine the electronics follow the same basic layout. FYI, I got a manual online through Sears for free.
Mine has a manual reset thermal overload protector to keep from burning up the more expensive stuff. It is the red "reset" button near the main switch that ought to pop out if it gets too hot, and can only be pushed back in when the machine is back down to a safe operating temp. I overloaded my machine, and the protector broke the circuit, BUT the button did not pop out and I therefore couldn't just push it back in. I took out the protector, and although it looked like the circuit should be closed, there was no conductance through the protector. I took off the tiny bolt on the back of the protector, essentially jostled the thing a little, replaced the bolt, and conductance is now restored. I re-installed the protector, replaced the front cover, and now she works like a charm.
So maybe these reset switches often don't act like they are supposed to? I'd recommend just checking everything in the line, beginning with the main power line in. it will contain three wires: the ground will be bolted to the frame, the others will run to the main switch and the relay, respectively. With the machine plugged in, touch your volt meter probes to the contacts on the way INTO the switch and relay, and you should have 120V. Then, check the switch by turning it to the ON position with the machine plugged in, leaving one probe on the IN contact of the relay, and moving the other to the OUT contact of the switch. Again, you'll get 120V if the switch is working correctly. Alternatively, you could just check conductance through the switch directly w/o involving the relay contact, either way is fine.
Next in line is the thermal switch, which was my issue. Unplug the machine and/or turn off the main switch (I do both, no point taking risks). You'll need to unscrew the switch, which is a black plastic cylinder about an inch in diameter with the red reset button on it, and check for conductance by probing the wires leading into and out of the back of the black plastic cylinder. If you don't get conductance, you're in the same boat as me, and try to fiddle with the bolt and restore conductance. Otherwise, it might be the relay or the capacitor on down the line. If not those, your motor might be shot, but we'll hope thats not the ca$e.
Hope this helps guys, I was really surprised that it turned out to be such an easy fix, you just need a screwdriver, a 3/16 wrench (for the bolt on the switch), and a voltmeter that tests up to 120V and can test for conductance. One thing to be very careful of is the large capacitor in the control box. I just stayed away from it, but I would seek further advice on how to test it if you need to. After taking apart a couple of cameras as a kid, I know not to mess around with those things. Otherwise, just use the same good sense you should bring to any fix involving 120V of electricity and a 10 inch steel blade.
Posted on Sep 06, 2008
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
Craftsman vaccuum filter
I think you are missing part of your model number. If you go to www.searspartsdirect.com you can enter your model number and it will pull up the correct filter for you.
Mar 18, 2012 | Vacuums
Parts for a craftsman shop vac
Hello. The best source of craftsman parts is sears.com
If they don't have these parts I will be very surprised. regards, Joe
Feb 12, 2010 | Vacuums
Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
May 09, 2009 | Shop Vac Vacuums
Table saw not turning on
yes that is a thermal fuse. wait a couple of minutes and reset it. If the blade is dull, replace it.
May 02, 2009 | Vacuums
USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The PB15 uses a fairly large pleaded paper filter for dry use, but it is an odd ball, as most of these type filters are held in place bay some sort of plate, and plastic nut. The PB15 uses a filter that has a bottom, and is pressed into place. For wet use, I would see if you can use the foam filter for one of the Craftsman small W/D vacs, like the old 2 gallon model, held in place with a rubber band, which is slipped over the cage with the float ball. It needs to be sealed across the bottom. That should cut down on spray making its way to the motor. The PB15 does have one good feature as the vacuum inlet has an elbow which keeps the water from being sucked straight into the motor intake, so the foam filter should do the job pretty well. I’d also look at the bag and rubber band that is used on some of the smaller Craftsman vacs, which sounds like what has been done on yours already. They are easy to find.
Because Genie no longer makes any vacuums or blowers, and did not keep a parts inventory to support owners of their products (a reason not to buy one of their garage door openers) it might be best in the long run to ‘garage sale’ the Genie, and buy a new vac from a brand that will be around for awhile. I have two Craftsmen, and one Ridgid, besides the PB15, which is going in the nest garage sale, for the above reason.
As far as your blower to vacuum problem -- The hose is moved from the blower outlet, which is the top black piece with the handle and switch, to the hole in the canister for vacuum. The intent of the PB15 was to use the top piece as a hand held electric leaf blower, or when attached to the yellow canister as a vacuum, when you use the hose attached to the canister.
Apr 16, 2009 | Genie Company GV150 Wet/Dry Vacuum
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Chain saw starts runs, bur saw won't start next time it is needed, craftsman chain saw
Steam vacuum? no clue but on your chain saw make sure you check the choke. it would explain why it wouldn't start again.
Sep 27, 2008 | McCulloch MC1275 Steam Vacuum
Craftsman 17026 Wet/Dry Vacuum Logo
1,485 people viewed this question
Top Craftsman Vacuums Experts
downhille
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
