Question about ASUS P5PE-VM Motherboard
System shutdown in 15 seconds
I have found an error in my computer. When I am switching on power button of my computer following messege is appearing :-
"Auto detecting USB mass storage devices ...
00 USB mass storage devices found and configured.
USB device over current status ditected !!
System will shutdown after 15 seconds."
After showing the above message the computer shutting down after 15 seconds. Even I cannot enter in BIOS setup.
I have checked all the hardware & USB port but the result is same.
If anybody help me i will very gratefull to him.
  • Anonymous Dec 13, 2008
    21212
  • goldilhyn Feb 17, 2009
    the same with this problem. The same motherboard..
    Problem Solver:
  • 42 Answers
Hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
Posted on Aug 12, 2008
  • Ashish Garg Oct 31, 2013
    gadhe ho kya banwari gupta kuch bhi bak rahe ho aise mode par jab statup screen se aage he nahi jaa raha to command tumhari pichwadi me chalyega woh??
    Problem Solver:
  • 19 Answers
Try to Reset you BIOS and Clean CPU Hit Sink and VGA Chip Hit Sink.....
Posted on Oct 31, 2013
Kesin çözüm.
Usb girişlerinden birinde bi yıpranma var ve içinde bulunan 4 iğneden biri şaseye temas ediyor. Yani zor kullanılmış bu noktaya.
Hayırlı günler.
Murat Canıtez
murat_canitez_1@hotmail.com
Posted on Dec 14, 2008
4 Suggested Answers
Hanto
  • 226 Answers
SOURCE: bios setup error
Unplug ALL Usb devices, that includes printers, cameras, pen drives, i.e. anything that plugs into a USB connector. Then try rebooting your computer. I bet your problem will no longer exist, but if it does, then you need to suspect a faulty USB connector on the motherboard or USB chipset located on the motherboard. Once the computer is booting normally without USB devices hooked up, you can start installing ONE Usb device at a time, until you find your defective USB device. The USB device drivers will need to be installed and computer rebooted at least once between the various devices. Not doing so will lead to confusion as to which USB device is causing your high current problem. It is also possible athough a bit unlikely that this procedure will cure your situation for the time being but look out for it in the future because it could be an early sign that one of your USB devices is going bad.
  • 508 Answers
SOURCE: System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
Posted on May 31, 2010
colliewob
  • 781 Answers
SOURCE: SYSTEM ERROR
1) if you have nothing in a USB port you will need to set bios
Try removing M/board battery for 2 to 3 hours some people say less then replace it most times it should set BIOS back to default
also check setup of hard disks master slave etc
Last resort with 15 seconds you should be able to see
press ?? key to access BIOS next boot keep pressing key see if that works
Posted on Aug 10, 2008
Dell e1505 won't power off
Check or Change the PSU or charger.
Jun 28, 2012 | Computers & Internet
Tip
How to shutdown your computer very fastly in microsoft operating systems.
step 1: click start menu button
step 2: click on the 'run' button
step 3: in the box that appears,type in the command ''shutdown -t 01"
the computer will start shutting down in 01 seconds
Note: By changing the value after the letter 't' in step three, u can set timer to shutdown for the specified value
for eg: the command ''shutdown -t 15" will set the timer for shutdown to 15 seconds.
on Jun 19, 2011 | Computers & Internet
May 31, 2010 | ASUS P5PE-VM Motherboard
All lamps are blinking. I cannot shutdown the system with the on/off switch
you shouldn`t actually turn off computers whith their power button always just click start or on you windows icon in the bottom left corner then click shutdown
May 16, 2010 | HP PSC 1510 All-In-One InkJet Printer
Screen says windows didn't start properly...help! :(
Acctualy you hadn't specified, that the computer is working and then you find this messege every time, or that the computer is not working and this messege appears every time, First if the computer is working properly and you recieve this messege every time, so you must check if you were closing the computer properly (closing all windows before shutdown), Second if this didn't work and the screen still appears, thats means there is corrupted system files due to many factors (from it Infection with a virus), and you must reinstall your windows.
Jan 08, 2010 | Toshiba Satellite A105-S4384 Notebook
Samtron 56v monitor control is locked
hold the menu button for 10-15 seconds.this shld unlock the menu. if the menu window still keeps popping up then u shld change either memory ic or power regulator..
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Bios setup error
check your c-mose battery when power cable is unplugged the battery remove and after few seconds battery fix them and connect power cable then on the computer
Oct 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Bios setup error
Aug 11, 2008 | ASUS P5PE-VM Motherboard
SYSTEM ERROR
Aug 10, 2008 | ASUS M2N-MX Motherboard
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
ASUS P5PE-VM Motherboard Logo
2,171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
