If you turn the monitor off then about 1020 sec turn it back on and have
a picture for five sec again it sound like the power supply in the
monitor. but if that did not solve the problem, the
picture board on your monitor is bad, since it goes off after few
seconds and the power led or button is on, it means the
board of your monitor has developed fault and will need to be replace.
I
advice you replace the picture board on the screen of your monitor to
solve the problem of the blank screen.
I think the problem with your monitor is that, the picture
board on the monitor is malfunctioning that is why it keeps going blank
after a minute.
What you need to do is to replace the picture
board on your LCD monitor, replacing the picture board will solve the
problem, because the picture board on the monitor at the moment is bad
Replace the picture board and you
will see that the problem will not repeat itself again.
after a minute.
The picture board on your monitor is bad, since it goes
off after few seconds and the power led or button is on, it means the
board of your monitor has developed fault. It can be repaired, all you need to do is just to replace the picture board on the monitor, after replacing the picture board, you will see that the monitor will work fine, just as before.
The problem looks like the picture board on you monitor is malfunctioning or let me put it right, the picture board on your monitor is bad that is why you have a blank screen on the monitor, i suggest you replace the picture board on your monitor in other to get it to display.
Replacing the picture board on your monitor will solve the blank screen problem.
If your monitor will hold pictures and your the screen is distorted, this is a sign that the picture board on your monitor is bad and will need to be replace in order to fix the problem.
Replace the picture board on your monitor to solve the problem.
It is the picture picture board on your monitor that is
malfunctioning, since the power led or button is on, but black
screen, it means the
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity
or any service center
to help with the replacement of the picture board
because the fault is not something you can fix yourself, in order not to
complicate issues.
to
complicate issues.
malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the
to
complicate issues.
The picture on your monitor won't come on because the picture
The best thing for you to
do now is to take the monitor to a local repairer within your vicinity,
because the fault is not something you can fix yourself.
