Question about Yamaha YST-MSW10 Computer Speakers
How do I hook up my 2 speakers and subwolfer to my computer.
My sub wolfer has 4 jacks, one in and one out, on line one. Then on line two, there are to jacks... one for the left speaker, and one for the right speaker. And of course, it's own power supply. On the right speaker there is the power supply and one jack for input 1, and one jack for input 2, and one jack that says "to left speaker". and another that says output. On the back of the tower there are two speaker jacks, but I only have three wires. I must be missing the forth. I have more wiring, but not a clue how to make this all work....................HELP!
    Sergeant:
  • 152 Answers
I have found the link for your instructions www2.yamaha.co.jp/manual/pdf/av/english/pcS/YST-MSW10.pdf
Posted on Aug 12, 2008
How to hook up the subwoffer
There are several methods, depending on the the types of 1)inputs on the subwoofer and 2) outputs on the amplifier (aka receiver). You can only use the type that is on BOTH.
Most sub woofers have "line level" inputs (they are the RCA phono style jacks or other style jack) that are marked "In" or "Input" and may have speaker level input & output terminal that accept speaker wires.
Amplifiers or "amp" all have speaker level outputs and many also have jacks that are labeled "Subwoofer" or "LFE" (low frequency effects) Output. If both your sub and amp have the "line level" jacks, then all you need to do is get a cable that is long enough to connect the two together, and then enable the low frequencies to be sent to the sub instead of the normal speakers in the receiver's set up menu. Done!
If you have only a speaker level connections common to both the sub and amp, you'll most likely need to disconnect the Main front L and R speakers from the amp and connect to the sub's Speaker Output terminals - and connect a couple of new speaker cables between the sub's Speaker Input terminals and the amp's Main front L and R terminals.
If you don't understand completely, provide the make and model of the amp and the sub, and I'll be able to clear up anything that isn't clear.
Mar 05, 2015 | Audio Players & Recorders
I cannot find the right way to hook my TS-W304C Subwolfers up to a mono channel amp.
what amp? the speaker wiring depends on the ohmage rating of the amp. if the amp is 2 ohm stable, then you can hook 2 TS-W304C's up to it, both positive leads from the speakers attached to the amp positive, and both negative speaker leads connected to amp negative. this is called parallel wiring, and it reduces the ohmage (resistance) down to 2 ohms. your speakers are 4 ohms, and 2x4 ohm speakers in parallel makes it equal 2 ohms. if your amp is only 4 ohm stable, then you will only be able to hook up one of your speakers to it.
Mar 13, 2011 | Pioneer TS-W304C Car Subwoofer
Need to hook up to keenwood powered subwolfer 1050sw and im a girl and dont know how
The receiver has a subwoofer out jack on the back. The powered sub has a LF input jack on the back. Connect the two with an audio cable that has 'RCA' plugs on both ends.
Mar 19, 2010 | Pioneer VSX-D409
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
I have a HK 595 sub. with no sattelite cables.
you need the the satellite speakers hooked up in order for the sub to work. its not a standalone sub the volume control knob on the satellite speaker is what powers on the sub. i have extra speakers i wish i could give you cuz my sub just blew out.
Dec 20, 2009 | Harman Kardon HK595 Computer Speakers
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
I-trigue 3000
my crative I_trigue 3000 speakers keep going off during music like its not getting enough electricity but is pluged into a seperate plug directly to wall.
May 06, 2008 | Audio Players & Recorders
SUB WOLFER WIRING
im assuming you have 2 subs that are DVC? if thats the case, wire from the positive on the amp to the positive voice coil 1 on sub 1 to the positive on voice coil 1 on sub 2. then do the same with the negative sides. then on the second voice coil of sub 1, connect a wire from positive to negative. do the same for sub 2.
Nov 27, 2007 | Car Audio & Video
Yamaha YST-MSW10 Computer Speakers Logo
211 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
