Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite he3 dryer
The dryer is making a loud noise and its coming from a fan like object, how the the problem be fixed
    Scholar:
  • 121 Answers
Some coins or other objects may have fallen down in to the blower housing. Unplug the dryer. The Front lower cover has 2 screws holding the outer panel on. There are several screws in the blower housing.
Posted on Aug 12, 2008
My dryer is a kenmore elite HE3 model number DADT-ELE-2406024-EL54 and is making a loud noise at the bottom in from
Dec 01, 2014 | Kenmore Washing Machines
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
Our Kenmore He4 dryer makes a loud noise somewhere between the sound of grinding the gears of a standard shift car and the noise that air wrenches make when the the lug nuts are fully tightened when...
Sounds like something is stuck in the fan. There is a squirrel cage fan that draws air through the drum. Take the front panel off and you should be able to see the fan. Or look in the lint trap slot with a light and see if you can see anything. I have also see the fans fail and come loose from the shaft.
Aug 07, 2013 | Kenmore Elite HE4 Electric Dryer
Loud screeching noise in kenmore elite he3 dryer
Likely one of the tension wheels has no lubrication. You may need to place dryer on its front and check the drum belt path. CAREFULLY lubricate the shaft if each tensioner wheel with vasoline - using a qtip.
Jan 05, 2012 | Kenmore Dryers
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Oct 05, 2008 | Kenmore 82822 Electric Dryer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
181 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
