Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
New Monitor in my computer using a xp profesional
I changed my old monitor for a flat monitor, when I installed was ok, just a little bright, but then I put the cd "adjusting Screen Resolution", after the installation, I re started the pc, then was a message of out of range, Please help me
  • 88 Answers
Restart your system and keep tapping the F8 Key as soon as you start the system. you should be at an advanced OS options menu, select SafeMode with VGA and proceed to logon to windows. Once in windows, right click on your desktop > properties > Settings > reduce settings to 800x600 > click OK > restart system. Now the display should be back on the monitor. Now read the manual to understand the highest supported resolution for this monitor + set the same as mentioned before on your system.
Posted on Jan 11, 2009
SOURCE:
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
I have just got an LCD monitor to replace my old CRT monitor but when i plug it in and turn and after windows has installed a little grey box come sayin 'frequency out of range and to change my display...
When you power up the computer press F8 key then Enter in "Enable vga mode".
Then go to start menu->control panel->display->settings.
Then change screen resolution to 1024*768 or 1280*1024 then apply and ok.
Then check .
Let me know if you need further assistance.Thanks for using FixYa.
Dec 20, 2009 | HP vs15 15"LCD Flat Panel Monitor
Problems controling brightness of monitor
well its not first hand ever.
its a vacuum tube CRT relic, why own such a thing>
the monitor old and weak, ask all such monitors are.
why pop for this. and end using junk like this again.
good luck with the VIRUS magnet XP,
you dont need a driver for any monitor
$30 wopping bucks, the price of freakn, potted plant.
why deal in 50lbs of glass and VACUUM??????
why walk past this deal. and walmart
https://www.walmart.com/search/?cat_id=0&facet=condition%3ARefurbished&query=computer+monitor&sort=price_low#searchProductResult
Jun 12, 2017 | Compaq P110 21" CRT Monitor
Dell computer windows xp pro. samsung syncmaster 731b cannot install right. says comp. cannot support default monitor installed ,
I need help monitor went blank and when I try to turn it back on it only blinks at the power button. took it apart and everything looks ok.
Mar 26, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
DISPLAY PROBLEMS
OK have you installed the Latest "Drivers" for your Video card? This is imperitive. Also get the Monitor Driver too, from manufacturers web site. Also can you try another monitor to see if it is "Faulty" Visat don't play nice with lotsa Video cards and Monitors if it don't have the correct drivers etc.
Jul 31, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
540n screen is bright white
Due to it is new monitor the best way to solve problem is to take monitor back to seller and afterclaim it. Malfunction is inside monitor and you are not able to fix it.
Good luck
Dec 11, 2006 | Samsung SyncMaster 152N 15" LCD Monitor
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
65 people viewed this question
Ekse
Clive
Clive
