Question about LG Dryers
LG Electronics DLG0452W Gas Dryer doesn't heat up. Drying lights are flashing and the cooling light stays on.
  • elkaymcf Feb 03, 2009
    LG DLG0452 does not heat up. It looks like it's fine, but air is cold. There is cold air coming out outside as well. Check filter light also flashing, but filter is clean.
Washer_tech
  • 164 Answers
SOURCE: Tumble Dryer not drying clothes
the problem could be several different things. first remove the front panel and see if the globar glows. if it doesn't check it for cracks and replace if needed. if it glows, replace your gas coils, they are usually the problem
Posted on Nov 01, 2007
SOURCE: LG DLG5988W Gas Dryer (NO HEAT)
got mine repaired.. They replaced the gas valve. Initial review is that its not drying as well as when it was new. I will use some more this weekend to confirm.
Interesting point on the washer....i have the same one i think (2277? - can't remember either). I've probably had the same issue with the bleach and never made the correction since I don't inspect the clothes before moving them over to the dryer. I will keep my eye out for that issue.
Never had the clunking noise though from the dryer.
Actually, I've been pretty happy with the two units until the dryer stopped heating...
Posted on Dec 19, 2007
MNTECH
  • 1543 Answers
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Posted on Dec 22, 2008
SOURCE: lg tromm dryer electric cooling light staying on
I started researching on here because I was having the same problems with my LG dryer. (It also happens to be the same model.) I discovered the vent hose was kinked.
With the lights, the cycle it's on that blinks. When your dryer gets to the last 5 minutes, the "Cooling" light will blink and the "Drying" light will go off. If you have the "Wrinkle" setting on after the 5 minute cooling cycle, the wrinkle cycle will start and circular lights will show where the minutes normally are displayed and the Wrinkle light will blink.
Posted on Dec 11, 2009
SOURCE: LG dryer DLG0452W not getting hot.
reset circuit breaker outside burner chamber, and cleaned out the unit.
Posted on Feb 25, 2010
The dryer is taking a lot longer to dry now than before. I'm sure it's not lint, insufficient gas supply or the vent needing cleaned. The cooling light is staying on solid and the drying light...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 06, 2011 | LG DLG2524 Gas Dryer
I have a LG (DLG0452W) gas dryer. It will tumble, but no heat. The light bars by the timer display are flashing orange instead of green. What could be the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 27, 2011 | LG DLG0452W Gas Dryer
LG DLG0452W: Light inside the drum stays on even after closing the door tightly and dryer does not start. It flashes to check the lint tray but there isn't anything in there. HELP!!
If that light stays on I would say something definitely is wrong with the door safety lock mechanism. I have an LG dryer service manual that may help you: LG GAS& ELECTRIC DRYER repair manual
Jan 10, 2011 | LG DLG0452W Gas Dryer
DRYER IS RUNNING, HAVE HEAT, WHY DONT DRY .
heatman101
Sep 27, 2010 | LG DLG0452W Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
Not drying completely
try cleaning real good. also the heating unit might be bad
Aug 05, 2009 | LG DLE2514 Electric Dryer
Cooling light
The lights that come on are what the machine is going to do for the entire cycle. If you notice it will start to flash towards the end of the cycle. That is when it's actually "cooling" the clothes to try and reduce wrinkles. The dry light flashes while it's drying. As for the not heating at all you need to check for blown fuses or popped breakers.
Sep 24, 2007 | LG DLE2514 Electric Dryer
Dryers Logo
61 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
