Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 all in one
Spooler service has been turned off and I can't get printer to re install.
Win xp picks it up but because spooler has stopped , can't install or use printer.
  • 659 Answers
Remove the previous install of all software and then try again unhook the power from the printer tho first and unhook the usb cable
hopefully it will install so you can turn the spooler on
Posted on Aug 12, 2008
Lexmark X1180 won`t install on new vista laptop
Okay this is a easy problem, the printer spooler service is turned off, just turn it on, and try to install it again, should work if not let me know.
press start and then run
OR
hold down windows key and press r
in run menu type in: services.msc
and press ok or enter
in services, you need to find printer spooler or spooler, right click on it and select properties.
make sure start up type is automatic, then press on start. Apply ok, close window , make sure the service status is running, press F5 to refresh the page.
try installing it now.
May 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark 1185
  1. Go to Start, Control Panels, Administrative Tools, Services.
    Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
  2. Right click on the print spooler and select Properties.
  3. Click on Dependencies to view a list of all the system components that the print spooler depends on.
  4. Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Nov 14, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Spooler service stopped
remove all s/w through add/remove programs
go to www.lexmark.com for new driver set(get the full one)
re install..
try it..
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP LaserJet 4250
go to Start> Run > CMD and press enter, then type 'net start spooler' for further trouble shooting as to why it is not auto running, go to Start> Control Panel (in classic veiw) > administrative tools > services
in there you will find print spooler, make sure that service is set to automatically run, you can also start the service from there and if it can't run it will give you the error as to why
Jun 09, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
X3470 printer installation
One of the most possible reason is related to Print Spooler service. Please check the "Print Spooler" service if its turned on. if its not you can turn it on. Here is the way to go Services screen
  • go to start menu then run and type "services.msc" then hit enter
  • locate the Print Spooler service in the services list
  • Change turn it on  switch to Automatic mode
Try reinstall
Good Luck
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
Installing of Printer
I had the same problem and like you couldn't find the solution and was verrrrrrry frustrated. Last night I loaded Vista Service Pack 1 (RC1). THE PROBLEM IS NOW FIXED. If you aren't comfortable loading a "beta" version you will need to wait until the first quarter of 2008.
Nov 30, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
