Question about Ricoh Office Equipment & Supplies
I have a PDF file of 145 pages, it requiers 9 Chapters to be printed and inserted into the document, but I can not seem to get the main paper draw to start print job. It says I have not selected Paper source. I need step by step. Having my work pulled from two places on the Ricoh Pro 1106EX
    Genius:
  • 1,689 Answers
Well usually in corporate printer you have to specify the paper source, if you have selected it and no happened, you may try other tray to put your paper on. if this should not work you may reset the printer by leaving it off and unplugged from the power outlet for at least an hour or 2
Posted on Aug 12, 2008
How can i get my printer adjust to eco mode
Set up your printer to save ink and paper (ECO MODE)
Step 1. To specify print settings in any open application go to File, Print or File, Print Preview, then choose Print Preferences. The options available will vary depending on the printer model you're using, but you'll probably be offered the ability to print in Draft or Economy mode and to a set page range.
Step 2. If you're printing long documents, reduce the page margins to fit more lines on each sheet. Open the program the document was created in and alter the margins in the document settings. Alternatively, you may be able to reduce the margins using the ruler guides. In WordPad, you'll need to look in the Page Setup menu.
Printing Advisor Printer reviews
Step 3. One way to save paper is to print more than one page of your document on each side of paper. Your printer will almost certainly have settings for this, and you may also find them within the software you're using. Be sure to check that the resulting text isn't too small to read, however.
Step 4. Duplex printing is the term used for printing on both sides of a sheet of paper. Not all printers are equipped with this feature, but it's a useful way to conserve paper and produce professional-looking documents. Carefully consider whether you want to flip the page on the long or short edge.
Step 5. Most programs have a print preview feature; use this to see how your document will look on the page before printing it out. You can tweak your page as much as you like, only making a final printout once you're happy with the result. This can save money on paper and ink usage, as well as reducing the wear and tear on your printer.
Step 6. Third-party software can help you reduce the amount of ink you use. InkSaver costs £20 or you can try it free for 15 days. We also like the look of the soon-to-launch Ecofont, which perforates text with holes that are invisible to the ***** eye in order to use less ink.
Print to PDF rather than paper
Step 1. A PDF is an exact electronic version of a document that's viewable on almost any device. A PDF protects the original document from editing by the reader, making the format ideal for marketing materials and digital magazines. Download and install the free version of Nitro PDF Reader.
Step 2. Nitro PDF Reader installs a printer driver that lets you export a document to PDF from any application's Print menu. To create a PDF version of your document, simply choose File, Print and select Nitro PDF Creator (Reader) from the list of available printers. Press Print and enter a name for your PDF.
Step 3. For greater speed and convenience, Nitro PDF Reader offers simplified, one-step conversion. Drag your chosen document from Windows Explorer on to the Nitro PDF Reader desktop icon. The conversion will begin at once, with the resulting PDF saved to your desktop.
Step 4. As well as exporting documents to PDF, the software lets you view them - if you're opening more than one then they'll appear on different tabs. Longer documents can be viewed as multiple pages by selecting the Tasks tab and then choosing between Single, Continuous, Facing and Facing Continuous views.
Jul 22, 2017 | PRINTER Office Equipment & Supplies
Document size and page size when printing
Its not a setting for page size, that must always be set to the paper size. The best way is to remove the margins in the document by editing it in a PDF editor. Alternatives are a bit of a bodge. When you print try changing the size to 115% of original.
Dec 19, 2013 | HP - HP Photosmart 8250 printer
Printing PDF on 8400 - example 265K PDF created from Acrobat 9 spools over USB over 22Meg and never prints. Any other files, Doc, XLS, we've tested print fine and fast.
I've ran across this a few times and the only thing that ever seemed to help was turning of print spooling so it would print direct to the printer. It ties up the computer while it prints but it does work. Usually in other programs when you see this kind of error the proper printer hasn't been selected or the paper size is wrong or the file being printed is corupt.
Mar 23, 2010 | Xerox Phaser 8400 Laser Printer
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Jan 18, 2010 | HP DeskJet F380 All-In-One Printer
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Feb 17, 2009 | Toshiba Estudio 200L Copier
Can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Jan 16, 2009 | Office Equipment & Supplies
Adobe Acrobat Pro 7.0 Can't get page numbers to show
OK, That's why it's not working.. In order to get them on there, do the following:
Once you have loaded the page into acrobat, goto the Document Menu, mouse over header and foot, and choose add..
In there, there will be a button that will say "insert page number", just click on that (only once), then click "ok".. That will add page 1...2...3...4, etc to the top of every page.
As a side note: you can also choose where to put the page number by clicking in one of the text boxes marked "Left Header", "Center Header", etc.. and then click on "insert page number".. You will be able to see a preview first before actually adding the numbers..
Mar 29, 2008 | Adobe Acrobat Professional 7.0 for PC
60 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
