The DVD rom doesn't work on my IBM T42 notebook. It can read and recognize DVD disc, but it can read CD. I checked driver from device manager, but it didn't show any problem. Could you help me for this issue?
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
There isn't a switch on the T42. (I'm using one to write this). the Function (Fn) key toggles the adapters but only if the correct utility is loaded. That is on the lenovo site called 1qkcb9ww or 8jvu12ww. Not sure which controls those features. If Fn+F5 doesn't do it... You otherwise usually get that message when there is a network adapter conflict and sometimes if the driver has become inactive which it does not too often. Try first disabling any other network adapters like Ethernet and maybe even the infrared network adapter though I doubt that could be it. Mine is disabled anyway. Do this in 'Network connections' from control panel for the Ethernet or with Device manager (Systems>hardware>device manager) if you never use a wired connection. If that doesn't help try reinstalling the drivers from the Lenovo site. Andrew L.
Check to see if your laptop recognizes it. Right click on 'My Computer' and go to properties. Click Hardware and go to Device Manager. Click on CD/DVD and see if you see yours in there. If not, you will need to get drivers for it.
If you see it, try restarting the laptop. Aside from taking the laptop apart to reseat the drive, it will need to be replaced.
I think it has failed.
Go to Control Panel...System... Device Manager... and locate CD or DVD Roms and UNINSTALL it. Then Reboot and it will automatically locate the CD / DVD Rom. You will have to acknowledge several screens wit naext and tes ect.
If it does not work, it's really easy to buy and replace.
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it .if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Check the driver in device manager. You would be looking for any icons with an X or a ? next to them. The driver probably isn't the issue, so I would search for the model number of your laptop plus "cd drive" on ebay. These are pretty cheap and are easily replaced. If that doesn't fixya, then there's possibly something wrong with the motherboard.
go to device manager under System Properties. Locate DVD/CD Drives, expand it, select your drive, right click and then left click on properties, select the General tab and check the state of the device IT SHOULD indicate the device is working properly, if so or if not, select the Driver tab unomstall the driver, reboot, see if Windows will reinstall the driver as it should recognize the device as a new drive. If not return to the device manager and reinstall the driver.
Unable to read a CD-R or other recordable disc.DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support
The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Internal the pickup assy. (the laser) there are three components that read the discs, one for DVD one for CD and one for the DVD-ROM its likely that the DVD-ROM laser has gone out.
Take the drive out and get the part number and look it up online on ebay or the like :-)
