Question about Uniden Cordless phone EXS9950
Uniden powermax 5.8 GHz not working
No service in or out. I have 3 phones and one base. Base keeps flashing "Welcome!
Please wait............
  • 1 more comment
  • bcr578 Aug 12, 2008
    I will try this solution and let you know.
    I left the base unpluged all night , then pluged it back in. Same problem. Now what?
  • bcr578 Aug 13, 2008
    I contacted the phone company because we had an outeg two days ago and they told me that the "Unden" is the worst phone system that he has known. They are "throw-aways."The base got fried even though I had it on a serg-protector. Everything else I had on that line was okay but the "Uniden" is just a cheap phone. I went to "Best-Buy" and bought a "Panasonic" for just a few pennys more and now have a real phone. Don't waste your money on junk like "Uniden"
    Sorry I wasted my money for advice from "FixYa". The "Technical Support Experts" should look into products like these.
    Brigadier General:
  • 6,966 Answers
Pls check if the intercom function works. If yes, then the base is simply waiting for the presence of a dialtone on the telephone line. It would be required to check your telephone wire connections. Further, if you have an extension telephone, pls verify that indeed you have dialtone along the same line. In most instances, you may need to contact your phone provider to verify service.
If no intercom function, it may simply need pairing again or redo the initial install setup.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 12, 2008
    Guru:
  • 1,894 Answers
Have you tried a hard reset. please leave the phone plugged off from wall power for one night and then try starting.
this may start the phone normally and problem will get solved many times.
thank you
SOURCE:
Uniden XDECT R055+2 . Hi, I was in the middle of listening to messages when the base unit started flashing Welcome please wait, and all 3 handsets have searching on them. The link light is also flashing....
this phone is the cheapest chines brand phone,with lot of problems,all you need to do is to go to service,because phone have bad solder,and all contacts must solder again,it is only problem,nothing else.
Jan 16, 2014 | Uniden Lands Phones
HEY, Just got DWX207 and it's not working. It's been charging for 48 hrs. and when you pick it up off base it is dead. I did push in the button on base firts. On base it flashes Welcome Please Wait
When you got it do you take the back off to make sure the battery is plugged into the phone? if yes! the phone clearly has a manufacture defect and should be returned.
Mar 24, 2011 | Uniden DWX207 1.9 GHz 1-Line Cordless...
Need to change my outgoing message on my uniden powermax DCT648-2
PRESS AND HOLD THE "GREET" OR "GREETING" BUTTON ON THE BASE UNITL YOU HEAR A VOICE THAT WILL SAY RECORD GREETING, START RECORDING THEN PRESS IT AGAN TO PLAY IT BACK TO YOU.
May 07, 2009 | Uniden 2.4 GHz Cordless Phone System
Phone says ''Welcome ... please wait'' when you try to use it
I tried to copy and paste the solution for this issue, but Fixya only allows so many charecters and I guess the answer is too long.
Go to http://www.uniden.com/index/manuals_results.cfm?cat=1
and select the owner's manual for your model phone. Follow the procedures for deregistering the handsets and then resetting the base. then re-register the handsets and you should be good to go. It is all pretty easy, just a little to wordy for this forum I guess.
Apr 04, 2009 | Uniden Cordless Phone
Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Mar 27, 2009 | Uniden TRU546 Remanufactured Dual Handset...
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Mar 04, 2009 | Uniden Lands Phones
DCT646 flashing Welcome Please Wait...
I replaced with a new battery and mine started to work ok
Jul 23, 2008 | Uniden DCT646-2 Cordless Phone
Uniden cordless phone - model DSS7855
Press and hold "end" and "#" for more than 5 seconds this will de-register your handset without the base unit.
[email protected]
see for more info. http://www.uniden.com.au/RESOURCES_MAIN/pdfs/ELITE8805_OM.pdf
Jan 21, 2008 | Uniden Cordless phone EXS9950
Uniden PowerMax 5.8
To make the message light go away when there are no messages - remove the handset from the base and press and hold the "find handset" key for 5 seconds. Resets it!
Hooray!
Aug 04, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden Cordless phone EXS9950 Logo
442 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
