Question about Philips 42PF9630A 42 in. Plasma Television
Resetting philips 42pf9730a/37 remote
The only thing that works is the volume. this has happened before and we just reset it but the instructions to do that are really hard to find! theres 2 buttons that need to be pushed, but i cant remember which ones.
My Philips 42in. LCD/Plasma HDTV has picture loss and is only a little over a year old. We first noticed that the sound would go out but,when turning the cable reciever and tv off and on the sound would come back on so we figured it was the cable reciever. Now recently the picture has failed and you can hear the sound. The menu isn't even visible. I spoke with a customer service rep with Philips and they are not sure but say it could be the power assembly making the picture fail. Could this be some software or firmware that needs to be loaded or will I have to have the power assembly replaced?
Steve W. I have philips model 42pf9730a/37 also and have the exact same problem as Scooba. Will not reset when left unplugged for one hour or more.
    Scholar:
  • 52 Answers
There is a firmware that can be updated via usb from philips. This fw was used to correct the tv powering on with no picture randomly (they called it a maintence session) but it was a problem. The tv would power on on its own and do this..
But... This will not resolve your problem if the set doesnt work when normally powered on. I know this first hand as I dealt with philips under warranty on this exact same set not too long ago.
The problem is with the main control board and y sus board. If the set is not under warranty, good luck finding the parts as they are $$$$$.
They replaced mine as they couldnt find the boards needed, I waited a month and said enough was enough.
But there is no simple fix for this one. Combination of 2 problems.
Posted on Aug 12, 2008
2 Suggested Answers
  • 52 Answers
SOURCE: resetting philips 42pf9730a/37 remote
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
PARMEET
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Update using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 14, 2009 | Philips GoGear SA3125/37 MP3 Player
Phillips Gogear SA5285/37 is frozen
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Anybody know anywhere I could get my mp3 fix?
-Tha Mp3 Doctor
Jan 15, 2009 | Philips GoGear SA3125/37 MP3 Player
My Philips SA5125 won't turn on...
You might have to use a button other than volume + in the instructions below - you can find out which button by running a Repair in the Philips Device Manager:
-Tha Mp3 Doctor
Jan 01, 2009 | Philips SA3025/37 Flash MP3 Player
Corrupted
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be gooOd to go again.
-Tha Mp3 Doctor
Oct 24, 2008 | Philips SA5125/37 MP3 Player
My mp3 does nothing.tried everything now what called co. also
-Tha Mp3 Doctor
Oct 18, 2008 | Philips GoGear SA3125/37 MP3 Player
Aug 07, 2008 | Philips 42PF9630A 42 in. Plasma Television
Most of the problems with the Philps 42" plasma (other than fuses) can be fixed with a firmware update.
If you have a PC and internet connection you can download the firmware and tranferit to a 1 gig USB memory stick. turn off the TV insert the Memory st, turn on the TV and it automatically recognises the stick will go into upodate mode with on screen instructions for the user.
They have had problems in the past with HDMI and volume, HD pixel problems, all of which got fixed in these updates.
It is very intuitive and if you have the slightest PC savy, anyone can do it.
44hink
May 31, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Philips 42PF9630A 42 in. Plasma Television Logo
261 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
