Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Screen damage? no problems in two years until today after shooting several "best shot" in monochrome, then returning to regular shooting position in color. no drops ever and only gentle usage. I turned it off and put camera away, then on turning it back on, the LED screen displays one-third solid white, one-third grey and only one third (bottom) of actual image. it also has an odd black "lips" image across the middle of top half. various colored lines across the bright part. I took battery out for a while, and shot more pictures using view finder, but display remains same--somehow damaged. any help out there?
    Sergeant:
    Champion:
  • 248 Answers
This problem can be sent to the manufacturer if you still have your warranty...this cameras strength is its weakness the LCD is virtually unprotected. cost of repair is more than cost of used replacement.
Posted on Aug 13, 2008
    Brigadier General:
  • 6,966 Answers
Most probably a faulty LCD display. Repairable and replaceable.
Hope this be of initial help/idea. If you are considering a DIY (do-it-yourself), pls post back or should you need additional information otherwise you might be better off seeking the services of a qualified professional.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 12, 2008
    Genius:
  • 1,689 Answers
You may try resetting the camera, go to the MENU then navigate to the setup tab the last item is Reset Camera. before you do this make sure that the memory card is not inserted.
if this should not work, you may try to load the firmware for the unit if it is available like other models, i will try to check on it too.
  • marlon john madrid
    marlon john madrid Aug 12, 2008
    this is the link where you will be able ot download the firmware and steps to do it.
    Exilim Firmware Upgrade
    if this did not work, you may then result to getting the LCD repaired / replaced.
    hope this helps.
    Guru:
  • 1,894 Answers
This is a clear problem of total death of the LCD screen.
you will have to replace the full screen.
no other go.
thank you
  • dewan nafees ahmed Aug 12, 2008
    but i would suggest one small repair before replacing the full screen.
    change the LCD interface bus cable.
    this can also be causing this problem.
    but we are not sure if your model uses a bus cable to connect to board. if this is a interface problem this wont cost you much for repair.
    if it is the LCD then its surely going to cost more.
    more over get it done by a authorized service center. because you can trust them.
    please post back in case if you have any more questions.
    thank you
    please dont forget to accept the solution.
I advise a high school yearbook and we shoot a d100. Today it's too dark to see through the viewfinder (yes the lens cap is removed), and i ger the r06 error. I've reset the camera, removed and...
First, the "r06" message is NOT an error code. It indicates the number of shots remaining in the internal memory buffer, before the camera must prevent additional shutter actuations so that it may transfer those images already in the buffer to the memory card. This "r" number will decrease with each shot taken in rapid succession until it reaches 0. The shutter release will no longer work until the buffer is transferred to the memory card, then shooting may continue again.
As far as not being able to even see through the viewfinder, it sounds like something may be obstructing the light from reaching the meter and viewfinder. The problem is most likely the position of mirror inside the camera body. With the lens off the body, the mirror should be plainly visible at about a 45 degree angle to the opening. A side view drawing of this is below. The solid red line is the mirror in the normal position. The red dashed line is the up position of the mirror when the shutter is released.
When the mirror is in the "normal" position, the light from the lens is projected on a screen so that the image is visible in the viewfinder for composing and can be metered. When in the "up" position (when the shutter release is fully depressed), the light from the lens is projected on the camera's sensor for as long as set by the manual settings or program; based on ISO, aperture, etc. At the end of this time, the mirror returns to the "normal" position.
If your D100's mirror is not in the lowered 45 degree angle position, the image seen in the viewfinder is inside the camera - not that which the lens would project. Hence, the dark viewfinder, long exposure times and - I'm guessing - severely overexposed pictures because way too much light is striking the sensor because the meter is only seeing darkness.
If the mirror is ok, with the lens removed from the body, look for the aperture lever as shown in the yellow circle in the picture below:
By default, the aperture is at minimum. The camera moves the lever from this position to full open (and anywhere between) as needed. You should gently move the lever to the other end of its travel to open the aperture to maximum. Point the lens away from a light source but preferably at a light colored background. Look through the lens. There should be no obstructions and be clear. Next, look at a dark colored background to find the same results. If you want, you can even allow sunlight to shine through the lens onto a sheet of paper (like a magnifying glass). The result should be a bright circle with no obstructions. Obstructions in the lens will prevent the meter in the camera from getting accurate information about the scene and if significant enough, prevent viewing through the viewfinder.
You may wish to have the camera & lens professionally cleaned and serviced to repair a mirror or lens issue.
If this was helpful, please rate it as such. Good luck!
Oct 04, 2011 | Nikon D100 Digital Camera
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
Film
35mm film, preferably ISO 200 or 400, although on bright days you can easily use ISO 100 as well. You can choose between 12 (scarce and not worth it), 24 or 36 exposures and check that the film has not passed it's expiry date as it can result in poor colours and contrast.
Users have their own brand preferences, Fuji and Kodak tend to have brighter and more vivid colours, Agfa tends to be more earthy and natural in tone, and most store own brands will tend to resemble Agfa. You won't go far wrong with any of them. If you prefer you can also use monochrome (a.k.a. black and white) film, but unless it says on the side of the box that it's "C41 compatible" then you'll need to use a processing lab which specialises in monochrome. C41 is the name of the processing system used for colour film and so C41 monochrome can be processed by a regular High St or drug-store minilab.
Jan 21, 2010 | Canon Sure Shot 150U 35mm Point and Shoot...
Nail would not shoot out
The problem that you describe is caused when the driver is not returning all the way back up to the top of the cylinder not allowing the nails to enter into position . You may have one of several problems including worn piston oring, bent driver, worn check valve, worn lower bumper, or low air pressure. Simple test is to manually push the driver blade back to top using a thin piece of metal that fits into bottom of gun. Be sure to disconnect from air supply when doing this. Good Luck
Jan 08, 2009 | Stanley Air Tools & Compressors
A95 Power shot Images on the LCD screen are monochrome,blurred with stripes
Unfortunutly this sounds like the cable connecting the screen to the main board is either loose or damaged. I would return it to the store you got it from.
Aug 26, 2007 | Canon PowerShot A95 Digital Camera
Help!
This problem is not related to plugging your camera into your computer. This is a symptom we have seen many times with various Sony cameras over several years of production. As far as we have been able to determine it is a problem with the sensor that feeds back the position of the zoom motor. I had a camera just a few days ago with this exact same issue. I swapped out the controller board and it did not change the behavior at all. I would suggest either sending the camera to a repair facility, or returning it to the manufacturer for service if you wish to get it repaired. The resolution will probably involve replacement of the set of sensors that feed-back the lens position to the control board. This issue is a problem with most Sony cameras, and as I said we have seen it several times and have not yet been able to identify the source. We forward cameras with this behavior on to Sony for service. David Millier Advance Camera Repair
Feb 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Out of focus viewfinder, zoom problems
1. Stop shooting while out on a shoot: Perhaps the batteries were running low? 2. Lens won't retract all the way and close: Could be same reason as #1.? 3. Viewfinder is out of focus in wide mode: Could it be that camera was left in "Macro Mode" (Flower icon)? Did you set, "Custom Function 1, or 2," and accidentally set the unintended exposure mode? 4. Sticks in telephoto, won't return to wide, blurry shots: Probably cold weather related? Perhaps, "reboot" the camera by removing all batteries for over 10-15 seconds, and replace with a freshly recharged set of NIMH batteries? If all of the above failed, then I'd say take it back to where you purchased it, and get a replacement unit. Good luck. ^_^
Sep 14, 2005 | Canon PowerShot A75 Digital Camera
Night shots
Hi: Well, I think you have a problem because you cannot take still shots at night :) Not even with the best SLR. The camera as to get light to make the picture. My advices are, not only use the tripod but when you shoot, but set the timer function so you don't touch the camera when it shoot's and use a high time of exposure like 2 or 5 seconds depending on the subject... Make several experiences with low resolution and when you suceed, make it with a higher resolution ;) Regards
Sep 04, 2005 | Fuji FinePix S5500 Digital Camera
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
63 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
