Question about RCA D52130 52" Rear Projection Television
Tv won't turn on, when i plug it it you hear like a spark and thats it no lights switch on tv don't work neither does the remote
  • tbeene Aug 20, 2008
    Same problem replaced a glass fuse but now we have power and sound but no picture....any suggestions??
  • RCA Master
  • 8,617 Answers
Youre flyback or HV splitter is whats giving you the trouble very famous in that model. You can get parts at the following link. If you dont know your part numbers leave them a message with your model number.
http://servicemanuals.vstore.ca/
Posted on Aug 12, 2008
LCD LE26R7 won't turn on after switching off
This is almost certainly a bad main board and it will almost certainly need to be replaced, not serviced.
I'd google for "LE26R7 main board" - check on eBay as well - but frankly if all you have to do is re-plug the TV in order to watch it I'd probably recommend sticking with that.
I predict there won't be a quick fix to this problem other than replacing the main board.
Don't kill the messenger :-)
bobby @ coppelltvrepair . com
Aug 25, 2012 | Samsung Televison & Video
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My panasonic tv wont turn on and led light flashes twice
Our Sony TV sometimes won't come on when the switch on the tv is pressed. Weirdly, if we switch it off at the wall socket, wait a few seconds, then switch it on at the wall socket again, the tv switch then works......
Don't understand why this works, but if it gives you a work-around, it would be a lot cheaper than a TV engineer's visit....
Feb 20, 2012 | Televison & Video
TV HAS RED LIGHT SHOWING WILL NOT SWITCH ON
Hi, The red light shows there is power connected to the set. The fact that it won't power up is due to a problem with the power supply circuit in the set. or a problem with the switch circuit or the mains power transformer. Regards John Ps don't know why they're giving me these questions, I answer questions on auto's
Feb 12, 2012 | Wharfedale Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My ps3 won't show on tv but it show that it's playing
Are you saying that it has sound but no video?
Plug only the video plug (yellow) to the TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 07, 2011 | Sony Playstation 3 (PS3) Console
The power light does NOT go off and the TV will not turn on. I know the TV works because every once in a while I will plug it in and hit the switch and it turns on. I tried programing a remote and then...
As far i can tell,u said the tv u unpluging,repluging the tv back awhile later the tv will function and work is that correct?Yes,this problems,alway related to the tv power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.U said u tried programing the remote,is the remote u have and using is a universal remote,u don't have the tv original remote?Yes,try website like Remotes.com to buy the tv original remote too.
Jun 20, 2011 | Akai LCT2060 Television
RCA D52130 52" Rear Projection Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
