Question about Toshiba Satellite M45-S2652 Notebook
Harddrive removal/ installation
I need to install a new hard drive on my toshiba satellite m45.
Where is it located and how do I access it ?
Thanks
P
  • 1 more comment
  • ppower7648 Aug 12, 2008
    Thanks found it !
    The hard drive I want to install is from a similar machine but not exact model # so the pins do not match up. Do you know if there is an adaptor I could use ?
    Thanks
    P
  • ppower7648 Aug 13, 2008
    Thanks again,
    I am learning a lot .I have a SATA Harddrive on both machines.
    The machine I am trying to connect the harddrive to has a 22pin connector from the motherboard to the harddrive. It appears I am missing a the hard drive connector from the hard drive to the machine (22 pin connector). It seems like it is specific to this model also as there is a different setup in a similar machine but different model as the connector will not slip off this similar machine.
    Is there a universal connector I can connect to this 22 pin male connector that I can connect to the harddrive or will I have to get this specific connector from the same model?
    Thanks
    P
    It looks like I was trying to fit a SATA to an IDE on the motherboard (44pin) on further examination .
    Why would they have 2 different type harddrives on the same model?? Is SATA more popular than IDE?
    Thanks
    P
    Genius:
  • 2,028 Answers
Flip the machine up side down, battery away from you, and you will see three covers. The center cover in the middle is the memory. The other two covers towards you, one on the left, the other in the center, the hard drive is under one of these two. I beleive it's under the one on the left, but it's been a while since I've had one of these machines in front of me.
Posted on Aug 12, 2008
  • Ryan Rogers
    Ryan Rogers Aug 12, 2008
    Hard drives come in IDE or SATA and are basically universal, depending on the type that the machine uses, ie... IDE hard drives will fit into any machine that uses an IDE hard drive, and SATA is the same. Check to make sure you don't have one SATA and one IDE, and also check to see if there is a hard drive connector on the end of the hard drive that was in your machine. Some machines have specific hard drive connectors that go on the drive in order to connect to the board. If there is a connector, it will slide off the pins on the end of the drive.
Toshiba satellite m45-s169 will not boot windows
Windows is corrupted or the hard drive has issues, if you have a cd installation disc try a fresh install, if no change! the hardware needs to be checked for possible replacement.
Apr 14, 2012 | Toshiba Satellite M45-S169 Notebook
In need of restoring to factory settings, (Toshiba Satellite M45). Held down zero, powered on, no beeps occur. The recovery utility never appears. Not listed in All Programs for Hard Disk Utility nor in...
It appears the recovery partition has been removed from your hard disk. You need to obtain a Recovery CD from Toshiba.
OR
If you have a Windows XP Home installation CD then you can use it to reinstall Windows on your Toshiba and the product installation code will be on the Windows label on the bottom of your laptop.
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jun 18, 2011 | Toshiba Satellite M45-S165 Notebook
Toshiba Satellite Notebook M45-S351 I recently purchased an upgraded hard drive - 160 GB Samsung Spinpoint and upgraded the RAM (Crucial 1 GB, bringing the total to 1.5 GB of the allowable 2 GB). Impetus...
Remove thwe new RAM and hard drive. Does it boot to the BIOS menu? If yes, add the hard drive and do the same again then add RAM and do the same.
I suspect something does not fit in properly. Probably the RAM.
Don't forget to initialise the hard drive if trying to format it. The System disk should take care of that.
Dec 21, 2010 | Toshiba Satellite M45-S351 Notebook
Hi, I re-installed the hard drive on this laptop (Toshiba Satellite M45-S169), but the hard drive is unresponsive. Not sure if I installed correctly, or the hard drive is dead. The power light comes on,...
If drive not spinning, definitely dead. If spins and not recognized by laptop cmos, the logic board on drive is toast.
Afraid that you have a nice cute paperweight.
Sep 03, 2017 | Toshiba Satellite M45-S169 Notebook
Toshiba M45 Satellite Won't Start
here is an issue with the operating system. Reinstall window and then try.
May 19, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite m45-s265 notebook
Check the harddrive is there in bios.
You can get into bios by keepnig the escape key pressed while it it booting, once in bios check that the harddrive is beiing detected.
Hard drive may need formatting if it is not formatted already.
Oct 12, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba M45-S351
Generally a bad hard drive, but it could also be an operating system error/glitch. Do a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the drive and install a new operating system. If you have any issues during or after the format and install, then the hard drive has failed and will need replaced.
Aug 12, 2008 | Toshiba Satellite M45-S351 Notebook
Need instruction "HOW TO" install DVD-ROM multi function drive inToshiba Satellite M45-S265 PC Notebook
Unfortunately I was unable to find a step by step guide for you, however I found a picture of the backside of your laptop. There should be only one screw to remove the cd rom drive located where the red arrow is pointing;
http://img367.imageshack.us/my.php?image=98bd1cl8.jpg
Simply remove that screw and pull out the drive :-)
May 11, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba m45 s165 - installing hard drive
http://www.retrevo.com/s/Toshiba-M45-S165-Laptops-manual/id/614bh526/t/2/
Above is the website for your laptop's manual. It should give reference information for hard drive installation.
Apr 02, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite M45-S2652 Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
