Question about Samsung Digimax S600 Digital Camera
Samsung Digimax S600 is stucked in off position
When I try to turn it on, it beeps 3 times but nothing happens.
I put new batteries in, same issue.
Any idea?
Thanks
JM
  • polshrk Aug 26, 2008
    same problem, and fixes yet?
    thanks
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Posted on Aug 26, 2008
When turned on camera beeps 3 times & the zoom
Does it take standard disposable batteries or a rechargeable pack?
If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries.
If the second type, recharge the pack.
If problem continues check Troubleshooting section of manual or online at Samsung's website.
Sep 20, 2011 | Samsung Digimax S600 / Kenox S600 / Cyber...
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Put new batteries in and it does not power up anymore. Beeps 3 times and nothing happens.
Are the batteries fully charged?
Does it work with the old batteries?
Chances are that the batteries are faulty. If they are in warranty it shouldn't be a problem replacing them with new ones.
Apr 03, 2010 | Samsung Digimax S600 Digital Camera
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
Samsung digimax s600 problem
it might be the battery take it out and put it back in. if that doesn't work then try a new battery. or it may be cheaper just to get a new camera.
May 19, 2008 | Samsung Digimax S600 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
May 20, 2007 | Samsung Digimax S600 Digital Camera
Samsung Digimax S600 Digital Camera Logo
141 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
