Question about HP Compaq Presario V2000 Notebook
Laptop screen my screen on my laptop is working but thers no light on the sreen wahts wrong and how do i fix it?
    Genius:
  • 2,028 Answers
Just to be clear, you can still see what's on the screen, but it doesn't light up? If I understand this correctly, and this is the case, then either the screen inverter has gone out and will need replaced, or the screen back light has gone out in which you will have to replace the screen. Unfortunately, the screen is considered a sealed unit and the back light cannot be changed out. You can test the inverter with an ohm meter. Get a reading at the motherboard end, it will be a low voltage, then check the screen end. I'm not exactly sure what the voltage rating is, but it should be real close to the voltage of the wall socket you're using, and it will be considerably higher than the motherboard end. If the voltage is the same or very close at each end, ten the inverter is bad. *IMPORTANT* Be very careful when handling an inverter, they can give you quite a shock.
Posted on Aug 12, 2008
I have ZEC LCD24HDS problem vertical lines on the sreen
Find another monitor, attach it to your laptop, hold fn key and press f5(works on most acer netbooks) if the lines still show up its most likely an integrated graphics problem, otherwise if it works you can either take off the screen and use it with the other monitor or you can replace the hardware. i can't remember what its called but a small circuit that lights up your screen could be the cause and is much easier to fix than putting in a new LCD
Jan 10, 2014 | Televison & Video
I have a Sony Vaio PCG-2J3L and when the lighting for the screen is on bright the screen will stay lite for a couple of seconds and then go black but you can take a flash light and turn it on the scre
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 04, 2012 | Computers & Internet
My sreen is all white and not showing any thing what do i do to fix it
Perhaps a hardware problem maybe the wire tape that connects the LCD screen to the CPU in your laptop is lose connect or perhaps the worst is your laptop LCD is damaged and needs replacement. The thing you have to do is bring your laptop to a good technician so that they can check what really is wrong in your laptop..I hope it help you..
Jul 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
My sreen stop working but plug to my tv an still works using another screen
If you shine a bright light at the screen and can see the picture then you may just require a ballast unit for the back light.
Ebay
Hope that helps.
Mar 03, 2011 | Toshiba Satellite L305D Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
MY SREEN GOES BLANK(white) WHEN IM ON IT WINDOWS VISTA
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Feb 27, 2009 | HP LaserJet 5550 Printer
My sony laptop won't turn on at all... no lights NADA!!
hiiiiii ther
how r u ?
do u hear a fan working ?
is ther any leds turn on ?
is it just the screen ??or is it the laptop tottaly dead ??
if it's tottaly dead than it could be aot of things
the power supple is not working or the motherboard fried
i'm sorry i wans't much of ahelp
give me more detales if u can
u take cae and have fun
salammmmmmmmm {bye in arabic}
Nov 22, 2008 | Sony VAIO PCG-K35 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
