Question about Whirlpool ED2NTGXL Side by Side Refrigerator
Ice/Water Dispenser How do I remove the ice/water dispenser cover on a Whirlpool refrigerator ED25QFXHW00?
Squat down and look up at the bottom of the cover where it meets the door. You will see two shallow slots where you can fit a flat bladed screwdriver to "pop" the cover loose. Once popped loose, disconnect the electrical connector by bending the locking tab out.
Posted on Jun 05, 2009
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Side by side Whirlpool fridge with ice maker as well as ice and water dispenser in door. Dispenser works for both ice and water so water is getting to the system, but the ice maker has suddenly stopped...
If you have a whirlpool icemaker inside of your freezer (I've read on other posts that whirlpool ice makers are installed in various makes and models), there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem. You see, behind the whhite wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your fitler either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
Mar 24, 2009 | Whirlpool ED0GTQXMQ Side by Side...
How to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Whirlpool Gold Side by Side Refrigerator
sounds like the switch tabs are broken off of the switch bracket behind the dispenser front cover. you should hear a distinct click when you oush in on either lever for ice or water if not then that bracket is broken.  if you'll look on the very bottom of disp cover you will see 2 slots insert a small flat blade screw driver and pry the cover off then you'll see a white bracket with switches and wiring on it look at the black switches and most likely the little plastic posts that hold them on are broken. the bracket is inexpensive and very easy to repalace. if you have any urhter questions just ask thanks peyton...
Jan 22, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2NTGXL Side by Side Refrigerator Logo
142 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
