I have a strong connection but limited or no connectivity with my wireless router. I clicked on repair and it cannot be completed due to: renewing your IP address.
    Scholar:
  • 65 Answers
Have you tried:
  • unpluging your router, waiting a few minutes (5) pluging it back in? sometime routers will need to be reset once in awhile.
  • have you checked the installation of your net-card? maby pull it and try a diffrent port.
  • contacting your ISP? it may be a networking problem up the road.
  • possibly try setting your network to a private setting. or making sure your network detection setting is turned on. you can find these options in your network and sharing folder.
I hope these options can lead the way to fixing your problem.
Posted on Aug 12, 2008
Trying to connect to my wireless router belkin n150 with my laptop compaq presario 2500 have a yellow triangle saying limited or no connectivity
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 01, 2013 | Computers & Internet
Tip
How to fix limited or no connectivity message with your wireless network...
How to fix limited or no connectivity message with your wireless network connection
When you move between wireless networks that use the same IP range and/or hardware it is some times necessary to manually renew your IP address for the new network because the computer still thinks it is connected to the old network.
Note sometimes all you need to do is reboot your computer and the computer will reacquire a valid IP address but from time to time a reboot will not fix the problem and you will need to go through the steps below.
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Now at the command line type "ipconfig /release" and press Enter
4. After the first command runs you will be at a command line again now type "ipconfig /flushdns" and press Enter
5. Now you will need to enter one more command, type "ipconfig /renew" and press Enter
At this point if you are wireless connection is not already connected it should be reconnecting to your router.
If you still get the limited or no connectivity message make sure that the router is getting an internet connection. You may need to restart your modem then your router to make sure that the router is connecting properly to your modem.
Also note in my example pictures you can see several connection listed this is because my notebook is connected to several networks. If you have a high number of connections you may need to reinstall the drivers for your network card. Doing this will dump and cached setting that may be causing your connection problems.
on Nov 20, 2010 | Computers & Internet
Release Router IP address
There are two ways to renew the IP address from the wireless router.
First method and the easiest - Right click on the wireless connection on the Task Bar and click on Repair.
Second method - Click Start - Run and "cmd" This opens a DOS Command Box, then type the command "ipconfig /renew all" and press Enter.
The Wireless router will issue a new IP address to yhr wireless card in your computer/laptop.
Jan 07, 2010 | Belkin Computers & Internet
Cant get my new laptop to connect to wireless - comes up with limited or no connectivity message. good signal strenght and laptop connects to other networks (eg at work) am worried that I have messed about...
Ok, the problem is that you can't connect to YOUR network right? Here's some things that could help you out:
  1. Make sure you reset your modem, simply unplug it for a few seconds. Then connect it again, select your network automatically.
  2. Make sure your internet provider's servers aren't down.
  3. Make sure modem is connected to your router properly.
Hope this helped. Good Luck!
Jan 03, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless network problem with Dell Inspiron 600m.
Your wireless router is acting as the mechanism to hand out IP addresses using DHCP.
Sometimes glitches occur and I would recommend unplugging your wireless router from its power surce, letting it sit for a minute or two and replug it back in.
It will come back to life , reset itself and start handing out IP addresses to all computers and peripherals that normally connect to the router.
Nov 27, 2009 | Dell Inspiron 600M Notebook
Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Cannot aquire IP address through my Desktop using Lynksis Wireless Router
sounds like you need to reenter the password/key
go to network connections and disconnect from it. then try to reconnect after the refreshes.
is it asking for a password/key?
Dec 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless network connection
Mine always does that when my IP address lease renews but it's an easy fix. You can usually click on the pop up that says limited or no connectivity then in the box that comes up click repair. If you cannot get to that box you can just go to start>control panel>network connections then right click the wireless network connection then left click repair. That usually works for me.
Hope that helps!
Jill
Nov 30, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin F5D8633 router - connected wireless to two laptops, two iphones and a printer. After working for a while, first one then the other laptop stops access to the web. The signal is showing strong but...
Are you running XP? have you made any changes to the router or the laptops recently?
Limited or no conectivity suggests that the IP has not been renewed. Have you tried rebooting the Router and the laptops?
Right click on the "wireless" icon in the botton right of the task bar and select status and then select the support tab. What is the Address type and IP address shown?
Try pressing "repair"
Jul 02, 2008 | Belkin Computers & Internet
No wireless
you have to renew the ip address.the easiest way to do this is restart the computer then try entering your net key.ALSO if you use a standard ethernet cable the computer may be trying to connect to the internet through that.what you want to do is disable the LAN connection in your network connections window and right click on the wireless connection icon and click REPAIR,this will renew your IP address also.If you do not know how to get to these settings go to START/ CONTROL PANEL/NETWORK CONNECTIONS then right click on your wireless connection then click repair.While your in that same window you can right click the LAN connection and disable it.To enable it simply right click the icon again and click enable.
Nov 14, 2007 | HP Compaq nc6000 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
