Question about Roper REX4634KQ Electric Dryer
6th cycle and clothes are still extremely wet.
I had a small load of clothes and put them into our dryer. it usually takes about 2 or 3 cycles to get them dry but it's been 6 cycles and our clothes are still soaking wet. I have no idea what to do, i'm a teenage girl so i have no idea about vents and all that. help plz!
I got it fixed. the hose needed stretched out, it wasn't putting out enough air. thank you though!
Posted on Aug 13, 2008
  • 876 Answers
Are you cleaning the lint filter after each load?
(Pull it out of the top of the dryer or inside the door and clean it )
Can you go outside and find the vent where the dryer exhausts air? when the dryer is running with clothes in it, is there air coming out? If not, It is plugged.
Whether you think it is pluggged or not,, go back inside and pull the dryer out from the wall carefully. If it is a stack job, get help!
Now the 6" diameter rippled tubing that connects from your dryer to the wall can be removed by loosening the clamp on the dryer with a screw dryer. I think you should carefully unplug the dryer before you start this!
Loosen the clamp and pull the hose off the back of the dryer. It may be full of lint and all sorts of interesting things which you need to clean out. Or you may find that it is not even connected. When you are satisfied that it is clean. place it back on the dryer (MAKE SURE it is not twisted) and tightened the clamp back on very well with the screwdriver. When you push the dryer back in place be careful not to push it in so far that you collapse this vent hose or twist it.
That's the dryer. NOW, when you remove the clothes from the washer do they feel still full of water? Is the washer spinning well and removing most of the water? If it is not this can cause your dryer to take forever to dry the clothes and it can also cause your dryer to overheat.
Whether you have a pile up of lint in your lint filter and hose or the washer is not spinning correctly, both are a huge fire hazard for the dryer, so TAKE CARE of this NOW. Please. and Good luck!
Posted on Aug 12, 2008
Permanent press cycle keeps shutting down and doesn't finish.
Hello. I don't know what make/model dryer you have but the problem could be with load size and type of clothing. The sensor bars are usually located on the front of the lint screen housing(you have to put your head in the dryer and look back to see them--they are 2 metal strips, approx 1/2" apart and at least several inches long). The damp/wet clothing keeps shorting across the strips, telling the main board to keep the dryer running. If there isn't enough of a load, the dryer may think that the clothes are dry prematurely and count down too quickly. The sensor bar technology *is not* an exact science--it works best on large loads with like clothing. For smaller loads, use time dry and adjust the temp setting accordingly. I hope I helped you.
Aug 22, 2015 | Dryers
Takes 4 to 5 dryer cycles to dry one load
usually thats a blocked vent to the outside..Its wet on the inside because its holding the condensation from the clothes .also check blower wheel ..One sure way is take your vent off the back of the dryer and dry a load if it drys in a normal time you know your out going vent is plugged
Feb 18, 2015 | GE Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Will not spin
The final cycle of any washing machine, including Whirlpool units, is the spin cycle. During this cycle, water is sucked out of the load, preparing the clothes for the dryer. If your spin cycle isn't working properly, your clothes will be extremely wet, which increases the length of the drying process. Troubleshoot, and repair this problem yourself to save money
Jul 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
My dryer will heat up, but it is not drying the clothes during the cycle. It takes 2 or 2.5 cycles to dry the load
if you have the top model lint filter take it out put your hand in and see if you have good air sucken,if not you have a clogg somewhere in the dryer hose or wall vent,most of the time it is the wall vent, if the hot wet air can't get out the cloths will take forever to dry-mike
Feb 06, 2010 | Kenmore Dryers
Intelli sensor doesn't read that clothes are wet,just damp.does not get clothes dry in intelli cycle.does get them dry in timed cycle.already replaced sensor.
do you stack clothes on top? If so take them off and try another load and never ever put anything on top. It insulates it and makes the dryer not run right. Good Luck
Feb 27, 2009 | GE DBSR453EBWW Electric Dryer
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Roper REX4634KQ Electric Dryer Logo
156 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
